Question about Hotpoint Ovens
Hotpoint BD52 oven very slow to heat up
This oven only 3 years old now takes 30 - 40 minutes to get to a medium temp such as 150 deg. Both top & bottom elements appear to heat up. It is no quicker on fan either - again element works. It gets there eventually, even to 200 (about 1 hr)
  • 979 Answers
You may have one leg of power that is out. First turn off the breakers, then back on. Check it to see if it is better. Then check the wiring from the receptacle, to the plug, to the back of the oven. Look inside the back of it and see if you see any fuses. They could be blown as well. If you are getting some heat (red) then it is an indication of a wiring or fuse problem. Now, one last thought here, if you turn it to high heat does it heat up faster? This one lead it to be in the control switch. Let me know how you do.
Posted on Feb 14, 2009
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
Have hotpoint single oven ,oven does,nt seem to get up to temp ie had it on full power 250 and placed a oven thermometer in and it only reached 150 any idea.nige
either the thermostat is faulty or the heating element is playing up ,check the wires as well in case you have a burnt/corroded terminal on the heater unit which is holding the amperage back
Nov 28, 2011 | Hotpoint Ovens
Hotpoint uy46 style line stainless steel, 2 year old, main oven fan takes 20 to 25 mins to start then runs too slow and some times stops, but the heat element is glowing red and very hot
The symptoms you describe are an indication that the fan motor is in imminent danger of breaking down altogether.
You need to replace it as soon as possibe, otherwise you will end up with the element burning itself out, thus doubling the cost of repair.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint UY46 Style Line Stainless Steel...
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Kenmore stove top elements incorrectly heating
This may be a serious malfunction that you cannot attempt to fix on your own. You should bring an expert to talk about this. Chances may be, you will need to buy a new oven.
Feb 03, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
KitchenAid Wall and Microwave Oven Combo - KEMS308SSS
Have had this oven for 8 years. At least three times, usually after using the clean cycle in the main oven, the latch mechanism has broke and the oven door will not open. In March they installed a 'new design' to prevent this. It's seven months later, and it broke again. Has anyone had similar experiences? How did you resolve?
Aug 27, 2008 | KitchenAid Architect® KEMS308SSS Stainless...
Oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Sep 20, 2007 | GE Profile JT912 Electric Single Oven
Ovens Logo
299 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
