Question about Sony 2GB Memory Stick PRO Duo Memory Card
Sony Memory Stick PRO Duo Not reading
When I insert my memory stick into my camera or computer it is not not showing up. I have photos on here that I really want, is there a way for me to access these?
  • 3 more comments
  • jprice375 Feb 16, 2009
    Thank you, I have tried this but still I cant access the images
  • taniacolvin Mar 22, 2009
    exactly the same problem - I am presuming that my MSPD is dead. I have only had it for 12 months but maybe that is as long as they last. Mine is full of photos!
  • Anonymous Apr 21, 2009
    camera and computer do not read memory stick
  • Anonymous May 11, 2009
    when i incert memory stick in my computer card reader it not show the photos and any follder but in camera it show my all photos. pls suggest the solution.
  • Anonymous May 18, 2009
    i have the same problems it is not reading
  • Sony Master
  • 32,281 Answers
Get a USB card reader, insert the memory card into the card reader and then connect the card reader into the USB port of your computer.
The computer will see the memory as an external memory device, now you can view the data/images and copy them to your computer.
Posted on Feb 13, 2009
2 Suggested Answers
Fixe_You
  • 1800 Answers
SOURCE: Unable to retrieve photos from 4GB Sony Memory Stick Pro Duo
use the sony utility that comes with ur device?
Posted on Mar 22, 2009
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
How Can I read my Memory Stick Pro Duo MARK 2 on my Computer? MY problem is I cannot read my Memory Stick Pro Duo Mark 2 on my computer but my computer is showing another Removable Disk(F:),which is my...
    • 1 Visit the Sony Support site (see Resources) and download the Sony memory card software. You will need to specify your operating system. Save the file to your desktop.
    • 2 Double-click the downloaded file to launch the installer.
    • 3 Follow the onscreen instructions to install the Sony memory card software. Restart the computer after completion. Once the computer starts back up, it will recognize the Memory Stick Pro Duo when inserted into the computer's memory card reader. You can browse the files using Windows Explorer or the installed x-Pict Story software.
May 31, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
My pc does not read the memory stick PRO duo sony...
my memory pro duo in camera show picture , when it conect with computer ,picture no t show.how can i do?
Dec 30, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
I want to download photos from memory stick pro duo of sony company
Use card reader and insert your cams stick pro duo memory card/chip into it. Then insert card reader into Pc usb and copy your photos from memory stick pro to your pc.
Aug 19, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
The pro duo memory stick cannot be used by my camera or read to see the photos
Make sure that contacts are clean on memory stick and reinsert it in camera.
Dues camera show any error sign when memory stick is inserted?
Did you tried memory stick in any other Sony camera?
Let me know to diagnose the problem.
Thanks.
Jul 11, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Camera can no longer read the Sony 16G Memory Stick Pro Duo
Sorry but it sounds like the card is pootched. Very common problem with these sticks. Best bet is to get multiple 2gb sticks to ensure that when one goes (and one will) you won't lose all of your pics
Sep 15, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Sony 2GB Memory Stick PRO Duo Memory Card Logo
1,700 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
