Question about Philips VOIP0801B/79 IP Phone
Compatibility with Skype v 4??
The Philips drivers which worked fine with Sykpe 3.8 don't seem to be compatible with Skype version 4.
Does anyone know a workaround, or a source of new drivers?
Thanks!
  • Anonymous May 21, 2009
    Yeap. Some of the phone function don't work with Skype 4.
I had a similar problem when I downloaded the latest version of Skype, my Philips VOIP080 USB Phone no longer worked, I could hear them, but they couldn't hear me.
I couldn't find a newer driver on the Philips website so I uninstalled my old driver then reinstalled it again and now it works.
Try it and see if this solution will work for you as well.
Here are the sites to find drivers for the Philips VOIP080 USB Phone
www.philips.com/support
or
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=INTERNET_TELEPHONY_DEVICES_CA&sct=CORDED_INTERNET_PHONES_SU&session=20090722024330_75.111.101.176&grp=PHONES_GR&ctn=VOIP0801B/37&mid=Link_Software&hlt=Link_Software
Posted on Jul 22, 2009
Can not get Adobe PhotoDeluxe2.0 to install on windows 7. Worked fine on Vista
Adobe Photo Deluxe is an older program that does not seem to be compatible with Windows 7. you should contact Adobe to see if they have an updated version.
However, you can try the following to see if it will help.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1)Right click on the Program
2)Click on Properties
3)Click on Compatibility tab
4)Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Oct 04, 2013 | Microsoft Windows Vista Ultimate Edition
Lenovo Easy Cam Shows Green Screen when using Skype
Hi
you have to google the problem and see if anyone else has that issue and how they resolved it.
it sounds like there is a compatibility issue with the Skype software and your windows i would delete and reinstall Skype or try a different version of skype.
i know over the last 10 years a lot of laptops have had ssues with the earler skype software.
cheers
Dec 07, 2012 | Lenovo G585 Laptop
The lord of king game is not working on windows 7 32 bit
A couple of things to try:
1) Running in compatibility mode: Rightclick the executable and goto properties, under the compatibility tab, play with the settings.
2) Make sure all of your drivers and directx are the latest versions.
3) Run as administrator.
4) If this is an old game, try downloading an old version of direct x from when the game was new. Install the old version and use the version of directx diagnostics included with the old copies install files, this will give you options that the newest version of directx may not have. (Useful trick for running REALLY old games) NOTE: Don't forget to switch back to the current Directx if you use option 4.
Hope it helps,
Jun 08, 2011 | Computers & Internet
Driver not support for windows 7
Try installing the driver in compatibility mode.
Instructions:
right click on the setup file --> properties --> goto compatibility tab --> click on the check box showing " Run this program in compatibility mode for" --> chose previos version of OS(xp, vista etc...) of ur desire ---> press ok
now run the setup file...
Thanks.
Feb 28, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Ms 211 webcam and skype version 4.0 for windows XP compatibility
You can try to download and install a program called SplitCam, which allows you to use your webcam as the video source in that program.
SplitCam then allows you to use the webcam in multiple other programs.
In Skype you can select the SplitCam video source, rather than the webcam itself.
Worked for me, hope it helps.
May 27, 2009 | Computers & Internet
Need to download voip080 phillips phone driver . Don't know where to get it.
you should look for it in Philips Support website !!! there you'll get all necessary software and drivers for a proper funcionality of your Voip080 ; and possible updates for new Skype version compatibility
May 08, 2009 | Philips VOIP0801B/79 IP Phone
VOIP321 - "ACCESS TO SKYPE DENIED"
http://www.support.philips.com/support/html/index_us_en.html TRY HERE.RICHARDM69
Dec 06, 2008 | Philips VOIP3212 IP Wireless Phone
Wireless music center PC installer V 2.0
  1. Right click on the DMM shortcut and choose Properties.
  2. Click the Compatibility tab.
  3. Under Compatibility Mode switch on the Run this program in compatibility mode for: checkbox, and choose the appropriate operating system e.g. Windows XP (Service Pack 2). Then click OK
4. Click on the DMM icon like normal it should then install.
Aug 06, 2008 | Philips WACS700 Shelf System
Philips VOIP321 not responding or connecting with skype
Just got the phone myself. I can only offer the same advice I would give to any other usb related problem.
first, put the usb device in another usb port.
Then uninstall the software, then reboot and reinstall.
You sound like you know what you are doing so I am guessing you have already tried this. God luck with your search for the answer.
Apr 19, 2008 | Philips VOIP3212 IP Wireless Phone
Phone not picking up contacts
Remove the batteries from the handset for at least 1/2 minute and reinstall them bach. This should work The contacts will show up again on tehe handset.
Dec 16, 2007 | Philips VOIP3212 IP Wireless Phone
Philips VOIP0801B/79 IP Phone Logo
476 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
