Question about Proview PL913S 19" Flat Panel LCD Monitor
Moniter clicking my proview moniter screen went white and then went dark. now all it does is click. the on/off button will not turn off. please advise
  • 558 Answers
Check capacitors inside for damage is found replace them
Posted on Feb 17, 2009
After 10 years with a Proview not Proscan RX326 TV, went from coax to HDMI from new Comcast digital adapter. Comcast & Proview remotes turn on TV but the screen often stays dark with no sound.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 06, 2016 | Proview Televison & Video
Dear sir/madam, I have a proview TFT moniter problem,when i on moniter than i found no display is appearing.
please check the moniter with different pc it can be the complaint with LCD panel.it is replacable plz vote
Mar 03, 2011 | Proview PA-32JK1A 32 in. LCD Television
How to ripless my coputer moniter.
right click and press the refresh button
Oct 25, 2010 | Proview Computers & Internet
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
I have a 32 inch 3200 model proview tv and it went black screen turns on and off what could be wrong or do i need a new tv
1: be sure that you have selected the correct input on your tv, there should be a button on the remote saying "input" or "source" 2: be sure the source is turned on and that the wires coming from the source are in the "output" receptacles and that on the tv they are on "input" receptacles. 3: it may be possible that one input is damaged or malfuncioning, try switching to a different input (example: from "Video 1 to Video 2, or HDMI 1 to HDMI 2). check the contrast settings on your tv, it may be set so dark that you cannot see well
Aug 12, 2010 | Proview Televison & Video
Problem with moniter
Techguru2009: You need to reset the bios to defaults and make sure all devices are connected before you turn your computer on. Make sure in the bios setup that the setting for the keyboard is usb support. If this does not work then you might have a faulty video card. Or you might need to reinstall the monitor in the operating system. If you are running windows operating system click on start button, administrative tools folder, select computer management. Alternative, click on the run command on the start menu and type compmgmt.msc. When the program starts click on device manager. On the right side of pane click on monitors. Find all monitors right click on each one and unistall all of them. When you restart your computer the operating system should recognize plug and play monitor and intall it automatically. I hope this method works for you.
Feb 26, 2009 | Acer Aspire™ T180 PC Desktop
My moniter screen is all white when I turn it on.
Hi sir,
Its a screen issue ..screen has to replace If it is under warranty go for service centre
Sep 21, 2017 | Xerox XA7-172i 17" LCD Monitor
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor dark PRoview PL916s
try to contact an expert technician of monitor maybe there is a part of your monitor that is already defective, the controller of brightness and contrast.
Jan 14, 2008 | Computers & Internet
Proview LCD TV
I am having the same problem. If I play with the power button on the back it will come on sometimes. I was looking for a solution here but looks like I will have to take it apart and check for loose solder joints.
Aug 01, 2007 | Proview HV-207 20 in. HD-Ready LCD...
Proview PL913S 19" Flat Panel LCD Monitor Logo
145 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
