Question about Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player
Car lost presets on ignition
Each time I start my car mij radio resets. I have an old vw so I know that the red and yellow wire need to be switched so my real question is
How do I switch those wires ? do I pull them out their harness or schould I buy a new adaptor were I can switch those wires ? or what ?
thanks in advance
Christophe
  • 1 more comment
  • Cdesolator Feb 13, 2009
    ok, but in my old VW the yellow wire from the radio is red and the red wire from the radio is red/brown. so how should I fix this ??
    ok done that, so in my car the red wire is is always on and the red/brown wire is ACC.
    but on my radio I have the always On wire on the place were the acc wire must be and the acc wire were the always on wire should be. do I need a new adaptor for my radio or do I need to rewire the radio wires in my car ?
    thanks Benimur,
    I tried it and it worked
    you just made my day :) !
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Let's start with the basics:
  • yellow wire to an always on B+12;
  • red to ACC terminal of IGN switch;
  • black to ground;
The yellow/always on is responsible for keeping the memory, that is the stations that you have had memorized/selected. The always on is directly connected to the battery's + terminal.
Would appreciate any updates. Good luck and thank you for using FixYa.
Posted on Feb 13, 2009
  • Louie  Role
    Louie Role Feb 13, 2009
    The best check then would be with the use of a DVM/VOM (voltmeter) or preferably a test light. The always on wire must measure/read 12VDC with or with the key in the IGN switch turned. On the otherhand, the ACC wire would only have +12 when the key is turned either in ACC or RUN/ON.
  • Louie  Role
    Simplest would be to switch them, no adaptors needed. The car's red wire should go to the yellow of the Pioneer and the red/brown wire which is ACC should go to the red of the Pioneer.
I have a panasonic car radio but when you preset your stations they work but then when you turn engine off for a few minutes they are lost cant figure it out drivin me mad
The red wire should be connected to the ignition/start system.Yellow wire should be connected straight to direct battery power(constant it's called).If the yellow wire is not hooked up to that,you will always lose your presets and clock when you turn off the car.Did you install it?If you need some info to do it,I will need the make/model of your car please.Just comment here and I will get an autolink to your post.Good luck! Greg
Sep 26, 2010 | Car Audio & Video
JVC stereo not working properly - 2001 Sonata
generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Feb 21, 2010 | JVC KD-R200 Car CD/ MP3 Player
Fitted clarion db148r car sterreo(pluged in at rear) when i take ignition key out stereo switches off and all preset radio stations are lost thanks george
The reason you are loosing all of your presets, clock & eq settings is because the 12volt constant is not hooked up properly. The red wire in the harness needs to be hooked up to 12 volt consant. The yellow wire needs to be hooked up to a ignition source. By taking these two steps, you should have normal operation and preset retention.
Sep 13, 2009 | Clarion DB148R CD Player
Kenwood KDC-W312S wont keep the saved channels after car restart
Check the yellow wire connection on your wiring harness... This is the wire that provides continuous power even when the ignition is off. This is how the radio remembers presets/time and such. Every time you turn off the car, the radio "resets" because you dont have the yellow wire connected to an ALWAYS HOT wire.
If you cannot find a hot wire, then you can run a wire from the yellow on the back of your radio directly to the positive terminal on your battery. Dont worry, it doesnt draw enough power to run your battery down.
Most cars have a cigarette lighter or power port somewhere that is always hot. You could always run the yellow wire off of one of these.
Just find a way to get the yellow wire on a hot wire and your stereo will remember the presets.
Mar 29, 2009 | Kenwood M-303USB Shelf System
Memory not working
check the yellow wire is the main power so always need to exist power on that wire even if the key is not on the ignition switch,and the red wire need to be conected to a switched ignition wire from the vehicle.
Mar 23, 2009 | Pioneer DEH-1100 CD Player
Radio Station Presets wont hold
hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
Nov 19, 2008 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
DehP6700 mp restet everytime keys is turned on.
first red is ignition or acc (turns off and on with the key) yellow is constant power (always hot keeps memory) orange is illumination (lights up radio) if vehicle doesnt have a seperate illumination wire connect it to the ignition wire. now process of elimination your ground is correct because it worked with all wires to acc your acc works because u had all them connected to it and it worked your problem is in your yellow or constant/memory i suggest u test it again take piece of wire any old thing long enough will do and run the wire directly from the battery under the hood and just run it outside the car through the window and connect it directly to the yellow wire make sure u have a good connection at the battery on the positive side if u have test light or volt meter test the wire before connecting it to the radio if it works then u know there is a problem with the wire from the vehicle (fuse wrong wire bad wire ) if it doesnt work make sure ground is connected tight and that paint is cleaned of the surface where ground connects and that the yellow wire to the radio is tight in the back of the radio.
Nov 13, 2008 | Car Audio & Video
Resets when car ignition is turned on.
you will need the code unfortunately, you can patch in a pp3 9volt battery but it is akward.
i suggest you go back to the garage and let them have a go swapping the wires round
Dec 02, 2007 | JVC KD-S6060 CD Player
Tuning the radio
You have two "hot" wires going to the radio. One is the main B+ power and the other is for the "mem" function which keeps clock time and radio station presets in memory. Make sure that you have 12 volts to the memory wire (blown fuse?) If you do then you may have a problem that requires a trip to your local repair guy. Do you loose your preset stations when you turn off your car and leave the face in place (wait several minutes before turning car ignition back on)? If that is so, then you most likley don't have B+ to your memory wire. Good luck.
Aug 16, 2007 | Sony CDX-L480X CD Player
Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player Logo
178 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
