Question about Acer Aspire 3610 Notebook
My browser works only with IP addresses.
I searched this website yesterday and it gave me a clue to connect Lan to my modem at home and check if my browser dispaly i.e. yahoo.com when typed as an IP address. And it did work. the same now at work while am conencted wirelessly.
So what's happened to my browser? is it anything fairly easy that I can do myself to bring my browser to the normal functionality to surf internet with typing proper website address?
  • kasprzakpawe Feb 13, 2009
    I have checked and I have all necesarry settings, IP subnet mask gateway, dhcp and dns 1 and dns 2. I think the problem might be somewhere within my laptop or just browser itself. Connection seems to be ok and when I type ip address for yahoo it goes on. I have just removed nasty bug as well which I thought migh cause hijacking my IE but it looks like it didn't change anything and browser still doesn't work.
Check in your "Network connection details" if you have a DNS adress. If it is like 0.0.0.0 you can't acces internet locations by name (like www.xxx.com)
Posted on Feb 13, 2009
I have no internet connection when i connect my adsl router with enhwi g2 router in WAN, then from lan1 connect my pc. Please solve my problem. Tnx
First test to see that you can connect to the Internet by connecting directly to the modem.
If yes, then check that the cables are connected correctly and that the LEDs are on. (Just a check :). Telephone line to LINE IN on modem then Ethernet/Cat 5 from LAN port on modem to WAN port on Encore router, then Ethernet/Cat 5 cable from LAN port on router to PC.)
Use browser (Internet Explorer, Safari, Mozilla) to connect to web interface of router (make sure your TCP/IP settings on PC are set to obtain IP address using DHCP).
Open browser and type in the IP Address of the router (192.168.1.1 is the default) where you usually type in the name of the website you want to go.
Go to the LAN Interface Setup page (you are now inside your router).
Change the IP Address from 192.168.1.1 to 192.168.89.1 (leave the subnet mask as it is).
Change the DHCP Client Range from 192.168.1.100 - 192.168.1.200 (the default) to 192.168.89.100 - 192.168.89.200.
Click on Apply Changes button.You may lose connectivity to the router, but you can reconnect by typing in the new IP Address 192.168.89.1. You may need to renew the IP address of the PC, but that can be easily done by rebooting the system if it doesn't happen automatically.
Let me know how you go, or leave a message if you still can't connect. I would ask that you tell me the model of the ADSL modem however.
Cheers
Dec 17, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
What is it?
default is http://192.168.1.1, but you can check by ip gateway (modem adress), on your computer.
check your local network connection:
if your modem is directly connect your computer, by usb or LAN the gateway adress is the same, you can test if go to the webrowser and type the same adress as before.
Dec 26, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My laptop indicates that I am connected to my home wireless network. However, when launching IE, I only receive message that I am not connected to the internet.
Try a direct connection with the modem and check whether you are able to go online.If not then its your modems issue contact your isp or if it works with the modem then check the ip address of the computer and also the internet port address it should not be 0.0.0.0 if it is so your modem is not giving the public ip to connect to internet.If its a dynamic modem do a mac spoof.steps open the netgear smart wizard page.
click on basic settings under setup menu and in that window in the router mac address select "use computer mac address "option and click on apply.Now click on router status under maintenance menu and check the ip address in internet port(it should not be 0.0.0.0) and in lan port(eg 192.168.1.2 or 192.168.0.2).If you get all these correct then it can be browser issue delete temporary files and cookies or try with different browser.Hope this will help u.Rate me if i have hepled you.Thank you
Oct 04, 2009 | Computers & Internet
Why won't my satelite modem communicate with my ethernet connection in my systemax venture computer.
hi there,
have you check your network connection,try to go control panel, check if you a network connection,check the driver of your ethernet on device maneger,if no driver install your lan installer,if your network is working properly,on network connection left click
local area connection properties.click tcp/ip,click properties and
type on the box your ip address manually example 192.168.0.1 and click that no. on the box to get your subnet mask,then close all until you get ip address manually,checking ip address on your network check on status,if you got manual ip address,then back again to network connection this time obtain your ip address on tcp/ip properties click obtain an ip automatically from modem,
besure to connect your modem on lan port.regards
Jul 04, 2009 | Systemax Computers & Internet
1 of 2 Dell Dimension can't get on line although shows connectivity
NO Internet
· power cycle the modem and router (turn-off the modem and router, and wait for 10-15 seconds before powering on the modem first, then wait for 3-4 solid lights before you turn-on the router; check a website, or else
· bypass router (by directly connecting your computer to the modem)
· checked a website
· checked the IP address by clicking start button for winXP, click run and type cmd, on the c:> prompt type ipconfig then hit enter, get the IP: if the IP address starts with 169.254.x.x…the type ipconfig /renew…or else type first ipconfig /release, then type ipconfig /renew.
· If media is disconnected, check the modem cable that runs at the back of the computer, unplugged and plug it back, or try other cat 5/ modem cable.
· Check the device manager for network adapter (is properly working), by right click on my computer, click on properties, and click on hardware tab, and click hardware manager button, click the plus sign next network adapters, makes sure there is no markings such ? ! or X marks, or else install the device manager for the Ethernet card.
· Type Ping google.com, check if the it receives and sends packet, if it does, then check the browser…
· Check browser settings, delete cookies, temp files on general tab…(click on tools->internet options), click on the connections tab, the make sure it is “never dial a connection”, check the LAN settings, make sure that there is no marks or checks on the boxes..click ok. Click on the advanced tab, click on the button “restore defaults”. Hit apply and ok. Close the browser, and open it up again and check for online website.
· Once connected, install back the router, if the there is no website shown, please your router brand support line for the reconfiguration of the router.
Apr 28, 2009 | Computers & Internet
XP wont connect to internet through Sky Sagem Router
NO Internet
· reinstall drivers first including the network adapters.
· checked a website
Apr 27, 2009 | Computers & Internet
Vista home premium
· checked a website
Apr 22, 2009 | Dell Dimension 3100 PC Desktop
Will not connect to internet
· checked a website
Apr 15, 2009 | Computers & Internet
Dell latitude E4300 wont connect to internet
Recently I purchased an Vostro 1310 for my mother as her Inspiron 1100 was dying; I installed all the drivers everything was peachy but frustratingly enoguh I could not connect to our home modem -
I alleviated this issue by taking it off obtain ip address automatically.
Then I put the following data in
IP 10.0.0.3
Subnet 255.255.255.0
Gateway 10.0.0.138
DNS preffered 10.0.0.138
Alternate Blank
I had to assign the laptop an IP as you can see and point it in the right direction which was to my modem. So all you need to do is find his modems default path and it should be sweet.
After I applied these changes it had no issues connecting - It might be a conflict of ip assigning on the network.
Before you rate get back to me if it didn't work - I want to help you solve this issue and get a Fix Ya! rating ;)
Blazamane
Jan 09, 2009 | Dell LATITUDE C640, P4...
Acer Aspire 3610 Notebook Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
