Question about Select Brands Washing Machines
How do i change the door seal?
I left the washing machine door open & the cat clawed a hole in the door seal. So i bought a new door seal, but how do i remove the old one & fit the new one.
    President:
  • 2,976 Answers
You'll have to find the screws that hold the door skins together. Take them out, replace the seal & reverse the order.
Posted on Feb 13, 2009
How to change door seal on miele w698
Normally they're held on with 2 wire rings, 1 at the edge of the seal at the door opening and the other on the edge of the outer drum. Unplug your machine and remove the lid, this will help access and give you more light to work with. Remove the ring at the door opening first and pull seal from the lip. Access can now be made for the one at the drum. Do the same for the one on the drum.
When putting in new one reverse the procedure and start at the drum, make sure you have the seal the right way around, normally holes in bottom of seal for drainage. Thread the seal over the lip and then put ring on. Same process for the front. Put lid on and plug machine in and test for leaks.
Dec 29, 2012 | Washing Machines
How to change miele novotronic W828 door seal?
Turn the machine off and unplug it! There are 3 10mm bolts around the door that need to be removed, the soap dispensing drawer needs to be taken out and you have 3 torx20 screws (one on the left and 2 on the right) that have to be removed. The bottom left corner of the machine there is a small door that you open, remove the hose that's clipped inside it, there is a small tab on the lower left, release the tab, pull open the door. To take out the seal you have to loosen the 8mm bolt band clamp, and pull the seal off. Fit the new seal on until you hear it pop. and reverse the order.
Hope it works for you.
Feb 28, 2011 | Miele W526 Front Load Washer
My 72640 AEG washing machine continually leaks even though the filter cap is tightly in place. What could be the problem please? Kate Comins
you have a hole in the rubber boot seal and need to change it,also i've seen a buildup of detergent and hair stuck on the bottom side of the front door,when the door is closed the water was traveling down the pieces of hair and leaking through the bottom of the door,but if it's leaking under where the pump is and it's not the pump or hoses it's the boot seal.open the door and pull open the boot seal and run your fingers all around until you find the hole
Jan 23, 2011 | AEG Lavamat 72640 Front Load Washer
Please, I want to Know, how ti change the rubber door seal? thank you.
Hello there
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some AEG machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the AEG door seal/gasket that locates on the drum makes fitting the new seal easier.
5 Your new AEG washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 Refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test your AEG machine for any leaks,
I
Jan 01, 2011 | AEG L66600 Front Load Washer
Wire spring on front rubber seal is off. how to replace.
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Aug 30, 2010 | Bosch Washing Machines
Fitting a door seal to a Zanussi ZWD 1270SA washing/drier
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Dec 28, 2009 | Zanussi ZWF1440 Front Load Washer
Clothes stink after being washed
run a empty load of just bleach and keep the door seal wiped down plus when your not using it leave the door open
Jan 11, 2008 | Washing Machines
WASHING MACHINE DOOR SEAL REPLACEMENT
Sep 17, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
453 people viewed this question
Top Select Brands Washing Machines Experts
Are you a Select Brands Washing Machine Expert? Answer questions, earn points and help others
