Question about Memorex MVD2028 DVD Player
No power on DVD Palyer (Akai P5580SK)
When I press the power button on my Akai DVD Player ( DV-P5580SK) nothing turn on.
can anybody help.
SOURCE: Does not load the DVD/CD. Says loading... for long time and nothing hapens
get a better dvd player. KLH SUCKS ****!
Posted on Jun 04, 2008
SOURCE: Memorex DVD player
  1. I have the same problem. I bought my Memorex October 5, 2008. Worked briefly 2x on weekend. Now, as of October 10, power won't go on and DVD disc is locked inside!!! My player does not click or blink!
Posted on Oct 20, 2008
SOURCE: DVD player will do nothing
Ok so I took the cover off to see if I could figure out the problem. Don't have a complete solution, but I did get somewhere. There is a silver cylindrical motor attached to the eject mechanism wheels on the VCR side. When I unplugged the tape from the back of the little motor, the progressive light goes out and the sound from the motor stops. When I manually turn the wheel/arm attached to the motor, the other wheels/gears turn and I can manually eject the tape. Also when I get to a certain point, my progressive light starts flashing like yours was. Anyway it all seems to be related to the little motor. I figure if you replace that, it would work. At least that is what I might try, I'll keep you posted.
Posted on Oct 30, 2008
SOURCE: Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Posted on Feb 14, 2009
  • 3 Answers
SOURCE: How can I make a Pioneer DV-420V-K DVD Player Region Free?
this involves burning a cd of new firmware
try here
http://www.videohelp.com/dvdhacks
Posted on Apr 12, 2010
Cant get my akai DVD player to play all my cds and dvds
Instructions
  1. Changing Region Code on Oppo and Similar DVD Players
    • 1
      Press the "On" button on the remote control to turn on the DVD player.
    • 2
      Press the "Setup" button on the remote control.
    • 3
      Press the following buttons in this precise order: 9210.
    • 4
      Highlight the text field in the window that appears. Press "0" on the remote control to change the region code from one-region specific (the country the DVD player is sold in) to all regions so that any disc can be inserted and played.
    • 5
      Press the "Setup" button. Press the "On" button on the remote control to turn off the DVD player.
    Changing Region Code on Sony and Similar DVD Players
    • 6
      Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray.
    • 7
      Press "Clear," "1," "4," "7," "0," "Clear" on the remote control. Press up on the remote control's directional pad until you see "1224" on the screen.
    • 8
      Press "2," "3" and the "Enter" button. Press up on the remote control's directional pad until you see "1401" on the screen.
    • 9
      Press "0," "0" and the "Enter" button. Press the "Return" button. Press the "Clear" button twice. The DVD player is no longer locked into the single region that it was designed for (being the country it was sold in) and is now instead open to all regions and so able to access any disc.
    • 10
      Press the "Return" button. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
    Changing Region Code on Denon and Similar DVD Players
    • 11
      Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray. Press "Clear," "1," "4," "7," "0," "Clear" on the remote control.
    • 12
    • 13
    • 14
    • 15
      Press the "Return" button. The region code of the DVD player is now changed from being only for the country it was designated for and instead for all regions. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
PROCEED ACCORDING AND FOLLOW THE STEPS. God bless you
Apr 04, 2013 | Akai Dv-px6150k - Multi Region...
Trying to reset dvd pioneer 270 out of progressive mode and nothing is working can hear sound but no picture
I just had that same problem with my Pioneer dvd player. I found the online manual for my dvd player. For restoring the default settings simply turn off your dvd player, then press the STOP button on the front panel of your dvd player while turning the dvd player on again.
Sep 05, 2011 | Pioneer DV-270-S DVD Player
When I start the movie the screen is dark and there is no vertical hold on the cyberhome screen
ur palyer is progressive mode u cahnge normal mode.press and hold stop button on ur dvd palyer front panel
Jan 26, 2010 | Cyberhome CH-DVD 300 DVD Player
Pioneer Dv 285 powers down after 15sec
Hi There, I've got the same problems with my DV 285. My power started going off approximately 5 to 10 minutes into the DVD. The only button that seems to work is the OPEN/CLOSE button. Once the tray closes, the unit shuts off. I can't even use the on/standby button to turn it on.
Feb 22, 2009 | Pioneer DV-285-S DVD Player
Pioneer DV 266
To solve "progressive mode" or any other problem on DV-266, just reset all setting to default, as follows;
Using buttons in front panel (not from remote control); - Switch off your DVD Player. - Press & hold STOP button, and press STANDBY/ON (power) button.
Good Luck & enjoy your Pioneer again.....
Apr 23, 2008 | Televison & Video
Yamaha dv-s5650
I have a Yamaha DV-S5550 and recently did the same thing. Our players may have the same menu system. Give this a try. Turn the power to the dvd player on. Using the remote, follow this key sequence exactly. Press the onscreen button. Press the down directional key once. Press the right directional key once. Press the down directional key six times. Press the right directional key once. Press the down directional key once. Press the left directional key once. Press the onscreen button. Your player should now be set to NTSC output. Good luck!
Feb 24, 2008 | Yamaha DV-S5650 DVD Player
Unlock procedure for Regions
1. Press Open/Close on remote control. DVD tray opens. 2. Press the following buttons in sequence: 2, 8, 1, 2. 3. TV displays "Region 2" 4. Press the Enter button on the remote until code changes to 9 5. Press the Open/Close on the remote. DVD tray closes. 6. Press Power on the remote control. Now code free...
Feb 19, 2008 | Televison & Video
Jan 04, 2008 | Onkyo DV-CP704 DVD Player
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Memorex MVD2028 DVD Player Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
