Question about AMD Motherboard, nForce4 SLI, S939, Athlon 64/64FX/64X2, Max. 4GB DDR, 8 SATA, 2 IDE, GBE, 1394a (NF4SK8AA8EKRS)
Flashing the BIOS
Ok, I want to use superupdate on an NF4SK8AA - 8EKRS.
do i need to mess with any jumpers? should the jumpers be set like in the 'readme 1st' .pdf that comes with the new bios files (from the foxconnchannel.com site)?
or do I just point 'superupdate' at the .bin file and flash it, and it doesn't matter where the jumpers are?
    Sergeant:
    Champion:
  • 237 Answers
You shouldnt have to mess with the jumpers only if you changed them before. The flash will flas the board in its current state. Just run the flash and follow the guidelines and you should be ok.
Posted on Feb 13, 2009
Need Foxconn SuperUpdate application for motherboard bios update please.
BIOS DRIVERS
Click the link above for BIOS drivers and updates you need for your computer set.
Enjoy.
Should you have any questions feel free to update tihs post.
Jun 03, 2010 | Foxconn 6627MA-RS2H Motherboard
Re: HP Pavilion m9150f - Need hardware solution for bios reset
just restart ur bias...by just reinsert the battery in motherboard...but it lead u to delete all ur datas in it...
Oct 27, 2008 | Computers & Internet
Dear sirs, i put wrong parameters in bios. so
99% of all bios don't need to be flashed or updated. Unless you have a specific problem with your bios and you go into the manufacturer's website and can read about the bios updates and see your problem as one of the ones that the bios update fix, don't update your bios. It's not going to make your computer run any better, it's not going to cure all the problems you have. About half the time it just messes up your computer or can ruin it. A lot of motherboard manufacturers have come up with Windows based programs to flash the bios but if they fail then you have to go back to the old method and they usually require having a floppy disk which most computers don't come with anymore. If you're one of those people that want to play around with your computer and do a little experimenting you're must better off to go format your harddrive, wipe it clean and start all over. Then you can go find all your new driver updates, software updates, find all the files you just deleted off your computer cause you forgot to backup before you formatted it. It's a lot more fun than flashing and updating your bios because your computer will still work when you get done. Sorry dude if the pin reset doesn't work the only option is possibly putting a new bios chip on the motherboard but I haven't seen one of those in years. Not sure they even still make them detachable and you'd have to find a motherboard to get one off of.
Dec 05, 2009 | EliteGroup L7S7A2 Motherboard
Foxconn NF4SK8AA-8EKRS will not post
I believe that there is no on-board graphics for that motherboard so I guess that you are using a graphics card?
  1. Try another monitor
  2. Try another cable
  3. Replace the graphics card
Sep 15, 2009 | Computers & Internet
Problem on start up
there should be a cmos reset jumper on the motherboard somewhere close to the bios chip. Given you didn't mention the actual model and brand of mobo i cannot be certain. Also you can remove the little watch battery for a few minutes and it too should reset the bios.
Aug 19, 2009 | Computers & Internet
Boot up failure
It's possible you are using a USB keyboard and it is not being detected. You should be able to turn the caps lock light on and off if it is working. Try a ps2 keyboard.
Apr 04, 2008 | Computers & Internet
Cmos resetting
Ok so you know the bat is good cause you checked the voltage. You double checked the bios jumper making sure it is not set to clear. Looking in your manual you can go to AMD XP3200+, & you are under that. So either you have a short or your bios needs flashed because it's messed up. Could have went when the cpu died.
Jan 15, 2008 | Biostar M7NCD ULTRA Motherboard
SLI NOT WORKING
well do u know what sli means? actually this is sumthing that u interconnect to video cards n its requirment is dat u'ave to download the latest nvidia drivers for it, if still da prblems not solved contact me!
Nov 18, 2007 | AMD Motherboard, nForce4 SLI, S939, Athlon...
After 18 month the computer will not go into POST on a re-start but will start normally when completed turned off.
simple. clear the CMOS by using clear cmos jumper setting or remove the cmos battery and put it again and then change the bios settings as per ur machine configuration.
Feb 23, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Restarting
It sounds as if you have a flat CMOS battery, remove and replace. To delete the password and bios settings locate 'JBAT1' terminal on motherboard and put jumper from pins 1-2 across 2-3 for a few seconds and then back to pins 1-2. You will have to reset time and detect drives in standard CMOS settings.
Jan 09, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
AMD Motherboard, nForce4 SLI, S939, Athlon 64/64FX/64X2, Max. 4GB DDR, 8 SATA, 2 IDE, GBE, 1394a (NF4SK8AA8EKRS) Logo
101 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
