Question about IBM ThinkPad T23 2647 Notebook
Hibernate My laptop (IBM Thinkpad Type 2647) is in hibernation mode. How do i get it back on? Or has it gone to sleep? When i put in the power cable the battery light shows up, but pressing the power button doesn't work. Please help!
  • IBM Master
  • 32,281 Answers
When Windows opens then -
Open Control Panel - then click on Power Options - Click on Hibernate tab and uncheck Enable Hibernate - Click OK
Posted on Feb 13, 2009
Neither Sleep nor Hibernate are available as options when I go to the Start menu on my Lenovo T410. They appear grayed out in the list that contains 'Switch User', 'Lock' and 'Restart'. Pressing Fn-F4...
Go to:
Control Panel\System and Security\Power Options\Edit Plan Settings
Choose Change advanced power settings link.
Here you can enable Sleep/Hibernate etc.
Sep 14, 2013 | IBM ThinkPad T41 Notebook
Cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
Hi, My IBM ThinkPad R51 type 1829 will not come out of hibernation/sleep mode. I have tried using all the FN and F keys, removing battery, etc. I recall this happening about a year ago and I had to...
This is called an ATX reset.
Remove the battery and the power cable.
Press and hold the power button for 30 seconds.
Put the battery back in and power cable.
Turn back on.
Apr 26, 2011 | IBM Computers & Internet
Think pad t42 monitor keeps turning off. I tried changing power settings to never ... did not help still doing the same thing anything else I can do? thanks
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 02, 2010 | IBM ThinkPad T42 Notebook
Computer goes in to sleep/ hibernate mode and I can not wake it up without shutting it off, and restarting
If we are talking "hibernate", then that's what the computer does - it saves the whole memory contents on the hard disk and shuts down. You then have to power it up and it boots like always on power up, but instead of loading the system the usual way, it reads the hibernation file and restores the state in which it was when hibernated.
"Sleep" or "standby" mode is different - the system stops execution of all the running programs, switches the processor into low-speed, low-power mode, executing only the basic functions of waiting for wake-up signal. Depending on machine and settings, it will be woken up by keyboard event, system event (like laptop battery running out - time to hibernate), network activity, or the power switch.
It should wake up when the Fn key on keyboard is pressed, the lid is lfted up (if it was closed of course), or when you momentarily press the power button. If it does not, then something is wrong with your ACPI/Power Management setup, and/or there are some drivers missing or corrupt. You can try going to IBM/Lenovo website and looking for updated system drivers for your model.
Dec 03, 2009 | IBM ThinkPad T43 Notebook
My name is Luis and my Ibm thinkpad r40 keeps freezing and my screen goes black.
Hi, could be simply your computer is going into sleep mode and not waking back up. try changing your screen saver option to not hibernate or sleep.
Aug 18, 2009 | IBM ThinkPad T40 2373 Notebook
My laptop has went into hibernation and shows a small moon and that the battery is in use. I took out the battery and it still shows it in use. It won't come out of hibernation and won't go back to...
The moon means Sleep or standby mode, if the laptop attempted to enter hibernation and sleep mode at the same time it could just be stuck in a hibernation loop and unable to load.
To test this, remove the battery and AC adapter, then hold your power button down for thirty seconds. Once you've done this replace the battery and power cord then try turning it on.
Let me know how you make out and if it doesn't work provide any other details you can including anything that comes on the screen and any beep codes you hear as it fires up.
Thanks and good luck,
Chris
Aug 10, 2009 | IBM ThinkPad T20 2647 Notebook
Can't wake up....gone into sleep mode...how do you wake it up
press and hold the power button down for about 5 secs. The computer will shut down. Restart it and right click on the desktop, go to properties then look for screensaver tab , then choose power options, click on hibernation tab at the top and uncheck enable hibernation. Or choose stanby options and choose a longer time before the computer goes to sleep.
Mar 21, 2009 | IBM ThinkPad T23 2647 Notebook
IBM ThinkPad T23 2647 Notebook Logo
370 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
