Question about Olympus Camedia C-450 Zoom Digital Camera
Navigating key -middle part- doesnt function
Navigating key found in the middle of the flash, timer settings don't work if pressed
    President:
  • 919 Answers
The problem you are describing is a problem with something on the main processing board of the camera. It seems to have failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product. The cost is $99 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
You may want to call Customer Service to discuss the repair process with them. Their telephone number is 800-622-6372 option 2 and then option 3.
Posted on Mar 16, 2009
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
My mouse pad doesent work
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys.
If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box. Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter."
Your touchpad will be re-enabled.
hope this helps
Nov 28, 2012 | Acer Aspire 7741Z-5731
Whenever I try to print anything or copy anything on the Cannon MF6530 it will print the first page then make a beeping noise and the red light starts flashing and it says change paper size - casette 1 LTR...
try to set the proper size for the paper in the printer.
press [Additional Functions] button (right of the LED display)
navigate to Common Settings
use [<-] and [+>] buttons to navigate to Select Paper Type and press and press OK
Confirm that Cassette 1 i selected (or Cassette 2 if you have optional installed)
and Set the paper type
next navigate to Reg. Paper Size, press OK, confirm again the cassette (1 or 2) and using the arrow buttons, set the paper size (should be LTR if you using LTR)
Sep 20, 2011 | Office Equipment & Supplies
We have a TI-89 and it is froze on the home page. we tried holding the 2nd button , left arrow , rigth arrow and pressing the on button. it comes up with installation in progress , but when that is done it...
Hello.
Here is a procedure to reset the TI-89 to factory settings (found online):
  • Press the "Snd Mem" key to display the memory screen.
  • Press the "F1" key.
  • Press the navigation key to select the "RAM" icon, then select "1: All RAM" to erase all data and programs from the random access memory and press the "Enter" key, or select "2: Default" and press the "Enter" key to reset all system variables to original factory settings. This preserves any user-defined variables, functions and folders.
  • Press the navigation key to select the "Flash ROM" icon, then select "1: Archive" and press the "Enter" key to erase all data and programs from the read-only memory or select "2: Flash Apps," then press the "Enter" key to erase all applications from the Flash ROM. Select the "All Memory" icon and press the "Enter" key to erase all data, programs and flash applications from the RAM and Flash ROM.
  • Hope this helps.
    Aug 21, 2011 | Texas Instruments TI-89 Calculator
    I need to change the menu language to English, as it turned to Chinese by mistake. Please help me. Thanks, El-sayed
    Hello, That's the same camera I have! I can help you. Follow this sequence to reset all the settings so that the language becomes English:
    1. Turn cam on
    2. Press the "menu" button.
    3. Press right directional key (marked with the flash symbol)
    4. Press down directional key to go to the bottommost entry of the menu (which is the reset all option)
    5. Press the "set" key (in the middle of the directional keys)
    6. Press the up directional key and then "set" to confirm.
    There. you're done. Now you don't have to learn Chinese to use your cam!
    EXTRA NOTE: BTW just in case this applies to you too; When I first got my cam, I had trouble finding the timer option to time the shutter (1-2-3 click!) It's called "drive mode" in this camera.
    May 07, 2011 | BenQ DC C1030 Eco Digital Camera
    I also am having trouble with this timer. I've got the program set for when I want it to go on but can't figure out how to put in the time I want it to stop. I don't understand where the countdown timer...
    ETW350 is programmable timer that offers 3 different timer
    functions: Program, countdown and random.
    Timer has 20 different settings.
    UPM site is not available recently, but UPM timers are still being sold.
    Operation manual is not very clear how to program ON and OFF times.
    http://waterheatertimer.org/pdf/UPM-etw350.pdf
    That being said, usually with programmable timers, you program ON time. And then program OFF time.
    I do not own this timer so I can't test ETW350 like I've tested other timers.
    I think the way this timer works, is program1 is ON.
    And program2 is OFF.
    Again, manual is not CLEAR about ON and OFF times.
    Following instructions assume timer is wired correctly, timer is set for current time, and you want to set 'timer' function and not 'random' function.
    Here's how to set program1.
    Press arrow buttons until 1 shows in display. This is program1.
    Press Set button.
    Select day for program1 ON using arrow keys
    Press Set button.
    Select hour for program1 ON using arrow keys.
    Press Set button.
    Select minute for program1 ON using arrow keys.
    Press Set button.
    Use arrow keys until 2 appears on display. This is program2.
    I believe program2 is for OFF times.
    Set program2 using same steps above.
    Be careful to match ON and OFF days ... for example ON 7pm Monday and OFF 9pm Friday will keep lights on from Mon through FRI.
    Conflicts in programming will cause timer not to work. For example program1 ON 7pm Monday, program2 OFF 9pm Monday ... but programs3-4 say opposite times.
    Make a schedule of program times before starting to avoid conflicts.
    Try steps above and test fire that timer, and then add a comment.
    Nov 24, 2010 | UPM Programmable Wall Switch Timer
    Lost instructions for TE 109
    1. Press and hold SET until day flashes. Use arrow keys to set
    2. Press SET again and hour should flash. Use arrow keys
    3. Press SET again and minutes should flash. Use arrow keys
    4, Press SET again to exit time-set mode.
    Sep 25, 2009 | Solar Ingraham 20 Program Electronic Timer...
    I have a Samsung d73 Digimax and would like to know whether this has a self-timer function and if so, how does one use it?
    No problem! Like all Samsung Digimax cameras, the self-timer is located by pressing the round navigation key once to the right/East/3 o'clock (it has a picture of a clock engraved on it). Pressing once gives a 10 second timer, twice gives a 25 second timer and the third press gives a multiple-burst self-timer whilst the fourth press will de-activate all timer functions. After selecting the appropriate self timer, depress the shutter button to activate.
    I hope that this helps!
    Dec 05, 2008 | Samsung Digimax S600 Digital Camera
    Lost manual -set timer
    Hi , In self timer is found in function set /press function set ,navigate the knob to drive mode , navigate knob to 10 seconds , click the shooter of camera then then okey.
    Dec 24, 2007 | Fuji FinePix S3000 Digital Camera
    Olympus Camedia C-450 Zoom Digital Camera Logo
    57 people viewed this question
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Steven Wander
    Steven Wander
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
