Question about Nokia N73 Cellular Phone
N 73 Stuck.
During I had download some software to N73 , I run update software. During that i unconnected N73from computer befor finished set up new software. After that I could not get N73 to computer.
Please sent me steps or program to set up softewater to N73 again.
Thankb you very much for help.
isah.
  • 436 Answers
If you could not complete your firmware installation,Please re install your phone with the same firmware using Nokia Software updater.
Posted on Sep 13, 2009
I was updating my nokia n73 software but my mobile get dissconnected during update so now its not getting start so what can i do?????????
Hello. Do not worry just do this
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link N73 files and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 13, 2011 | Nokia N73 Cellular Phone
Sir, actullay i was updating my phone model no. nokia N73 but it got dicconnected in between and now it is siwted off and now it is not being swited on....so what should i do????
If you contact me before you do this, I comment you to don't ever do this because updating via pc suit/ovi suit works success only 10%.The connection lost frequently during process.Now the only solution is to contact Mobile repairing shop or if you want to do it by yourself follow the procedure below First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link N73 file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck For your N73 flash file
Due to the different types of N73 available , Open http://www.blue-nokia.com/index02.html and in the left side of the window there you will notice BB5 SUPPORT click there and you will again see various models of Nokia Mobile Handsets.Then, make a selection to N73.Again there you'll see different download links.choose the last one i.e. 7.23 v7(Global) by clicking to the download link you will lead a new windows.I think this is enough.......you can when you get there.Thanks
Sep 05, 2011 | Nokia 3110 Cellular Phone
I am abhay. during update my nokia n-73.my cell phone is switched off.
Hi,your cellphone during you update is automatic switched off.if your cellphone automatic off you need to reprogram your cellphone,beacuase your cellphone is corrupted or full of memory.you need to go the repair shop cellphones.thanks :)
Aug 10, 2011 | Nokia N73 Cellular Phone
Nokia n73
go to iunlock.com for the repair of ur dead nokia n73.
u can do the by mailing ur phone to iunlock.
nadeem
Oct 25, 2008 | Nokia N73 Cellular Phone
I have a lemark x1100 series all-in-one. I need a driver for my computer so I can use it on my computer. The wizard couldn't find a driver and I lost the disk that came with it. My computer has windows...
Here is the download page.
Click and download software into my docunent,
when finished run software installer from my documents.
Unplug printer usb cable before and during software installation, this is important.
Jul 23, 2008 | Lexmark Office Equipment & Supplies
N73 start up problem
Your phone needs to be reprogrammed, only a repair shop can do this for you.
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
May 05, 2008 | Nokia N73 Cellular Phone
N 73
If it's a signal strength problem, it's more likely to be your Network Service Provider than your phone. However your internal aerial might be faulty.
You could try a restore to factory settings, but I don't think it will change anything.
Updating the Firmware might help.
-_-_-_-
WARNING
May 01, 2008 | Nokia N73 Cellular Phone
Turn off during software update
sir, i updated my Nokia N73 software but its shut off its self and can't turn on again...
Apr 29, 2008 | Nokia N73 Cellular Phone
N73 software update - phone not working
DO NOT-----DO NOT---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again. But give it plenty of time.
If the PC freezes during an update, you're up the creek without a paddle...
Jan 04, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
137 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
