Question about Toshiba Qosmio G15 Notebook
Card slot not working on qosmio f20
I reformatted my computer and now the memory card slot is not reading an SD memory card. is there a driver or something i can install to fix this?
    Scholar:
  • 50 Answers
There is. You'll need to download it from Toshiba's support page. Try this link:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=835451&rpn=PQF10U&modelFilter=F15-AV201&selCategory=3&selFamily=804517&selModel=835451%7CPQF10U
Click the Downloads tab, and where it says Refine Search By: click the All Categories drop down menu, select SD. Run the donwloads available there.
If the above link didn't work, use this one:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support
Posted on Feb 13, 2009
What formatting is necessary to play videos on the SD card slot of my Magnavox NB500MG1F Blu Ray Player?
The SD card is mainly for photos, but you can do video.
The SD card needs to be formatted as fat 16
The video has to be profile 1.1
If you use the larger SDHC cards, they can be formatted fat 32.
It works best if you format it with the player and not your computer.
May 17, 2014 | Magnavox NB500MG1F Player
Magnavox NB500MG1F Blu Ray Player: I've been having trouble getting the SD card slot to read the videos I put onto the SD card. I've tried everything from converting all the video files to AVCHD file types...
It is obvious to me that the player can't read the video off an SD drive. In my experience that card slot is for installing updated firmware not video material.
Mar 23, 2017 | Audio Players & Recorders
My pc dont read micro sd scandisk 2gb, I need drivers
buy a cardreader.put the micro sd memory card in the cardreader's slot.connect cardreader to the to the computer and the computer can read your memory card.
May 31, 2011 | SanDisk 2GB microSD Memory Card
Memory card stuck inside Memory card slot.
Your only bet is a pair of tweezers, The SD slot is not "openable" When these fail the whole reader assembly is disconnected from the motherboard and replaced.
I would say try your local beauty supply store or a pharmacy for a longer thinner pair of tweezers.
Should that not work you have to decide which is the lesser of two evils paying for a tech to replace the component or just leaving the card in there and forego the use of the reader.
Another option is to use a heavy gauge sewing needle to try to push the micro sd card towards the front where yo can grab it with the tweezers.
MAKE SURE the battery is pulled out and the laptop does not have power.
Jan 07, 2010 | Computers & Internet
Refurbished digital cameras c330 and c315 are not reading Koday memory cards
C330 and C315 its compatible Only in 1GB SD card or maximum 2GB SD card. More than this it cant be recognized by the camera or to reformat it.
If your card is 1GB SD card still its now working it means the memory card slot of the camera is defective.
Nov 12, 2009 | Kodak EasyShare C875 Digital Camera
5in1 card slot won't read cards
i think you need to install usb 2.0 drivers on your comp
Sep 16, 2009 | Acer Aspire 5610-4648 Notebook
Error F20 unable to detect internal memory
The internal memory on the F20 is actually an mini SD card inside the unit and this fault is caused if the card can't be read. This is mostly likely because there is a poor connection to the card. To cure the problem:
1) Remove the two screws on the bottom of the unit.
2) Divide the two halves of the case. Its best to do this by using your finger nails or a plastic lever. If you use a screwdriver or something similar you will most likely damage the case. Take care when you finally are able to divide the two halves of the case not to strain the cables connecting the battery and loudspeaker.
3) You should be able to see the SD card in its holder on the circuit board. To remove the SD card pull the top edge away from the board and the top half of the holder should hinge outwards. Don't try to pull the card out as you would do from a normal external SD slot.
4) Examine the terminals for any corrosion or contamination. In most cases just removing and re-inserting the card does the trick. You can safely switch the F20 on with the case still open, but don't attempt to insert or remove the SD card with the F20 turned on as this may damage the circuitry.
5) If this doesn't solve the problem the card itself may be corrupted. You can check this by inserting it in a computer card reader to see if it can be read that way.
Dec 27, 2008 | Navman F20 GPS Receiver
Additional memeory
You might be running into a problem with the new card being a SDHC (Secure Digital High Capacity) card and not just a SD (Secure Digital) card. I have had similar problems with SDHC cards when I put then in older products that have regular SD slots (Photosmart Printer). The cards will still fit into the slots, however the method as to which they are read and written to is different which causes the problem. So, maybe try updating computer hardware drivers or mp3 firmware from the Sansa website. Also, if you can, exchange the 4gb SDHC for a 4gb SD card, this could be a pain in the ****, but this solution should fix your problem definately. Hope some of this helped.
Aug 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Reformatting an SD memory cardf
You can format the card in your camera while not connected to your computer. In fact it's recommended to do so. Read your instruction book to find out how. It should be a selection available from your "menu" button when in image review mode. Select "low-level" or "full" format, not "quick" format (quick format is only good for erasing pictures).
Jan 12, 2008 | Cameras
Toshiba Qosmio G15 Notebook Logo
218 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
