Question about Sharp AR-5316 Advanced Digital Imager Copier
LSU HOW MUCH LSU UNIT?
    Problem Solver:
  • 4 Answers
The part number is.
duntk0343rszz the cost will be £135.00
Posted on Feb 17, 2009
Samsung ml 2551 Engine hsync error
Dear The problem is with LSU (laser scanning unit) unit. If you are experience open the lsu clean all optical path and test. This may operate .Replace the LSU unit.Thanks.
Oct 13, 2014 | Samsung ML-2551N Laser Printer
My suamsang printer lsu irror
LSU unit can be damaged in time if the printer is used alot. You may need to call service and replace your LSU unit and HVPS in order to avoid future LSU failures.
Apr 03, 2013 | Samsung SCX 4521F All-In-One Laser Printer
How to troubledhoot the LSU error on samsumg
repalce laser unit or check menu # 1931 lsu mirro test
Aug 03, 2010 | Samsung SCX 4521F All-In-One Laser Printer
What is err0r code E 7 02 IN ARM 450 COPIER
The E7-02 means the beam detect sensor never received a beam from the laser. As the previous poster stated you'll need a new laser unit. Meaning that you need to change the whole laser unit but not the polygon motor.
E7 02 Content Laser trouble
Detail BD signal from LSU is kept OFF, or ON.
Cause The connector of LSU or the harness in LSU
is disconnected or broken.
The polygon motor does not rotate normally.
The laser home position sensor in LSU is
shifted.
The proper voltage is not supplied to the
power line for laser.
Laser emitting diode trouble
PCU PWB trouble
Controller PWB trouble
Check and
remedy
Check for disconnection of the LSU
connector.
Use DIAG (SIM 61-1) to check LSU
operation.
Check that the polygon motor rotates
normally or not.
Check light emission of laser emitting diode.
Replace the PCU PWB.
Replace the Controller PWB.
Mar 15, 2010 | Toshiba E-STUDIO 650 Copier
Engine LSU error printer model samsung ML2150
how can over come from LSU error problem in samsung all in one machines
Jan 21, 2010 | Samsung ML-2150 Laser Printer
MY samsung scx-4521F LSU ERROR. HOW TO RESET THE PROBLEM
No reset will work, it is detecting the Laser Scanner Unit is not operating correctly and it is a replacement unit (LSU).. the lsu is a high speed motor with a many sided mirror attached spinning at very high speed (you can hear the whine in lasers of the spin), the motors wear out and cant spin fast enough yo spread the light and need to be replaced... then your error will clear
Nov 07, 2009 | Office Equipment & Supplies
Engine LSU error, printer will not print. Accepts paper half way then it stops.
lsu stands for laser scanning unit. it tansfers the image onto the transfer drum, common problems are horizontal sync, i would suggest a replacement lsu
Sep 24, 2009 | Samsung ML 2151N Laser Printer
Have lsu error also.
Hi ...
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
Cheers ....
Jul 28, 2009 | Samsung SCX-4100 All-In-One Laser Printer
LSU Error
LSU (Laser Scanning Unit) is a device inside the printer that create images on the drum.
If you see LSU Error on the display, it is indicating that there's a problem with LSU unit.
  • Unplug the power cord and plug it back in.
  • Check if the printer makes any humming noise.
If the problem persists or does not make any noise, LSU needs to be replaced.
If your unit is under warranty, please contact our tech support at 800 - 726 - 7864.
Otherwise, please find nearest Samsung Authorized Service center from the link below.
Dec 06, 2007 | Samsung SCX-4216F All-In-One Laser Printer
LSU ERROR shows in display panel
The Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge inside the machine could be dirty. The mirror motor in the LSU could be bad or needing cleaned so it spins better. Laser diode could be bad.
Sep 20, 2007 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
