Question about O2 Jet Cellular Phone
DEFAULT PASSOWRD FOR O2 JET
Can some 1 ploease let me know the DEFAULT PASSOWRD FOR O2 JET
PLEASE THANKS
  • punitkotak Feb 13, 2009
    U R GR8 ! ! !
    THANKS A TON ! ! !
  • Anonymous Mar 21, 2014
    default security password
  • 679 Answers
The default security/handset code for the O2 Jet is 1234
please rate this solution.
Thanks for using FixYa.
Posted on Feb 13, 2009
Code for unlocking o2 xda11i
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 06, 2012 | O2 Xda IIs Pocket PC
My o2 sensor has gone, but i do not know where it is to replace it. Please help!
The O2 sensors located beside the cat converter.The one is pre-cat converter and other is pro-cat converter.The 1 before the catalytic converter and 1 after it. The 1 before is called the upstream and the 1 after is the downstream. ----------- Thanks.Helpmech.
Nov 12, 2010 | 2005 Chevrolet TrailBlazer
Netgear NG834G router has had pasword altered and I cannot get in. Fix?
Please check the password uppercase and lowercase characters while typing in.
This type of devices donot come with password recovery option.
The only solution will be reseting the device but that will erase all the configurations and device will go to default settings.
So if the only passowrd is set and all other settings are in default mode , you can reset the password and login through default poassword.
Oct 30, 2010 | NetGear DG834G Router
91 chevy 4.3 v-6 runs extremely rich when engine is cold gives codes 13, 33 and 54 I know what these codes are but I need to know is could the computer coolant temp sensor or the air cleaner temp sensor...
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 54 Fuel pump circuit low voltage
Start with checking the wire leads to the O2 sensors and MAP sensor. Look for any damages to the wire harness and replace any parts damaged or faulty.
The O2 and MAP sensor take reading and sends it to the ECM to recalibrate the fuel injector pulse to adjust the amount of fuel entering the cylinders. When there is an issue to the O2 sensor or MAP sensor and even both, the ECM will be set a a factory default to run rich to keep the engine running and at times the engine may not even run. Normal fuel to air ratio is 14.7:1 - 14.7 air to 1 parts fuel and at default it could be as high as 12.5:1. Good luck and keep me posted, be glad to help you get your truck running 100% again soon and please rate. replacing the thermostat and temperature sensor would also be a good thing since the 4.3 runs best at 190".
Jan 10, 2010 | 1991 Chevrolet S-10
I NEED THE PASSWORD(CODE) FOR SAMSUNG JET. IT IS NOT 00000000
i have a samsung mobile phone S8003kkznu,my mobile working not fine from very first day,so many time visit at service center,now main board change but after change the mother board indian software not updated when i switch on the mobile screen show go to vodafone live 7 mobile phone hang some time,please help me
Dec 29, 2009 | Samsung Jet S8000 Cell Phone
HP Solutions Center, wrong icon on screen
Hi
1.Please check in Printer n faxes whether it show both the printer HP 1500 series and HP Desk jet 3800 series.
2.If the printers are listed, in the solution center you will find two printers listed, by default it is set to Deskjet printer. Select HP 1510 printer to use the scanner feature.
Please respond after trying this.
Thanks
Riz
Dec 28, 2008 | HP Office Equipment & Supplies
Forgot Login
You will need to hard reset the whole unit unfortunatly, there should be a reset button on the back of the unit that would do that for you
you might need a sharp head to do that, usually hold that button down for 5 seconds and it will reset your device, you will have to go back and re-set up your network tho.
make sure you find the manual first to get the default log in and password. i believe they are
Log in; admin
Passowrd: admin
please check manual before resetting because you might lose connection.
Hope this helps
let me know
Thanks
Apr 30, 2008 | Allied Telesyn AT AR220E Router
Mobile tarcker password
Reset phone *2767*3855# , remember it totaly reset the phone so all settings will be gone and your default pasword will be 00000000. Please dont touch phone afther put in code, it will atomatic restart and reset.
Dec 19, 2007 | Samsung SGH-E900 Cellular Phone
O2 Jet Cellular Phone Logo
136 people viewed this question
Top O2 Cell Phones Experts
Computer Repairing
Computer Repairing
David Burbee
David Burbee
ivan georgiev
ivan georgiev
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
