Question about Nokia N95 Cellular Phone
BLUETOOTH when i select nokia orignal them my cell will be automatical start
  • 126 Answers
For changing themes in nokia. phone memory equal to size of theme should be free. For ex. - if theme size is 215kb then phone memory should also have 215 kb free space . Free some space in phone memory and then try.  pls rate.thank you
Posted on Feb 13, 2009
Www nokia help line
Switch On your Bluetooth BH112, turn on Bluetooth in your Nokia 502, it will search for available Bluetooth Devices and on discovery, will ask you to select one. In the list, select your BH112.
Go to www.nokia.co.in for more information and support.
Apr 26, 2014 | Cell Phones
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
How to connect the plantronics explorer 233 ?
  • Make sure your Plantronics Explorer headset is fully charged and turned off.
  • Press and hold the call control button (the button on the face of the headset opposite the earbud) for six seconds. When the light begins flashing blue and red, the headset is now ready for pairing with your phone.
    Select the Menu on your cell phone. Once the menu is displayed, select Settings, then Bluetooth Menu.
  • Select the option to add a new device. This will both turn on Bluetooth capabilities in your phone and put it into a setting known as "Discovery mode." The phone should discover your Plantronics headset automatically and display "XXXPlantronics." ("XXX" represents the model series number, such as "320Plantronics.")
  • Select the Plantronics option on your phone. In many cases, the phone will automatically recognize the headset, but if you are prompted to enter a passkey, proceed to the next step.
  • Enter "0000" if you are prompted for a passkey. Your headset will flash blue once it is successfully paired with your phone. Once paired, the Bluetooth headset will automatically recognize your cell phone each time it is turned on
  • Feb 01, 2011 | Nokia E63 Cell Phone
    Nokia C5 bluetooth disconnects automatically, phone automatically switches off
    sir, you have to change the default memory from phone to memory card. for this go to menu- messaging- options- settings- other- memory in use- and change it from phone to memory card.
    Nov 15, 2010 | Nokia C5 Cell Phone
    I forgot my nokia 1209 security code how can i unlock it
    i forgot my nokia 1209 security code how can.
    Jul 11, 2010 | Nokia 1209 Cell Phone
    My nokia 7210 bluetooth not working when we switch on bluetooth the mobile automatic switch off
    my nokia 7210 bluetooth not working when we switch on bluetooth the mobile automatic switch off
    Sep 19, 2009 | Nokia 7210
    Connect ACER Aspire 5100 w/ nokia 3120 , using
    It is very simple provided that your system has a Bluetooth, and you have a very recent Nokia PC Suite, preferrably from version 7.1.18.0 and above. If you dont have, you can just go online and download a copy from either :
    http://europe.nokia.com/get-support-and-software/download-software/nokia-pc-suite
    or
    http://www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-PC-Suite.shtml
    Just Install the Nokia PC Suite on your system, and make sure that your system 's bluetooth as well as your phone's bluetooth are switched on.
    Thereafter after installing the Nokia PC Suite, when you are prompted to select connection type, just select bluetooth and click next. The software will then try to automatically detect your phone and pair with it. It might ask you for a passcode, just use 1234, or any other number you like.
    Hope this helps you out.
    Jul 12, 2009 | Acer Aspire 5315 15.4-inch Notebook PC
    My nokia 3110c has a problem in opening the inbox.when i try to open the inbox the phone automatically gets off and starts again.kindly help me resolve.
    GO SETTING AND PRESS RESTORE AND CLICK IT ASK PASSWORD ENTER PASSWARD PHONE WILL RESTORED ORIGNAL SETTING
    NOTES:
    IT DELETE ALL PHONE MEMORY
    EX:CONTACT
    May 03, 2009 | Nokia 3110 Cellular Phone
    Nokia 3230 started then open menu then select setting option then select phone then select general then select orignal phone setting then display a code box that is i forgot help me
    Your display circuit is broken, even if the LCD-panel,
    seems to be ok the display is damaged.
    This is a very common problem in Nokia phones.
    The only way to fix this is to change the display.
    You need a T-6 Torx Skrewdriver to do the job.
    You can find displays for fair price at :
    www.mytrendyphone.com
    This is your solution! Please vote!
    Oct 22, 2008 | Nokia 3230 Cellular Phone
    Nokia N95 Cellular Phone Logo
    37 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
