When I start any cycle, water begins to leak. It leaks throughout the cycle, becoming heavier when draining for the spin cycle. I tried to prop up and look under unit to locate the source, but I cannot view it. I am now having some trouble removing the rear panel to try and get a better view. Anyone who has had the same problem and could save me some time, please help.
This one you remove the whole outside case and not the back.
Remove two screws on each side of the back control panel, you may have to remove the plastic trim on each end of the panel. The control panel flips back so you can remove two brass clips, unplug the wireing in the back center. The whole outside case can be removed.
