Question about Macromedia Flash MX
Scolling images in left to right
Flash animation
    President:
  • 392 Answers
Dear friend your answer is too long for here but I suggest you a website.you can find your answers about flash there easily by a simple search.
http://www.flashkit.net/
But if you couldn't get your answer send me a mail, I'm at your service.my mail: fardinfard.h@gmail.com
Good luck
Posted on Feb 13, 2009
  • Hussein Fardinfard
    Hussein Fardinfard Feb 13, 2009
    dear friend the answer is too long, I suggest you this website:
    you can find your answer there easily by a simple search.
    if you won't find send me a mail, I'm at your service. my mail:
    Good luck
I have a apple smartphone and i would like to know that, although we cannot see flash on Apple phones, why can I see the flash from this website http://www.hookedupinstalls.com/ and I cannot see the flash...
Apple doesn't provide any kind of compatibility for flash animations on their iOS devices (iPod touch, iPhone or iPad). The difference between both websites is that the latter does use flash, as the first one doesn't. This may be confusing because the only thing that both websites do is to just fade images, but your first website uses a new technology called HTML5. You see, when a website designer decides to create an animation through flash, the plugin is the one that does the animation, whereas when he decides to do it via HTML5, the browser is the one that does it. As you may imagine, if your browser doesn't have a flash plugin, you won't be able to watch the animation.
Here's a sample code (in HTML5) to make images fade in and out http://tutorialzine.com/2010/09/html5-canvas-slideshow-jquery/
--Dennis
Feb 19, 2011 | Apple iPhone Smartphone
Tip
How to make your photos 3D with normal camera
<p>3D images are interesting, but they depend on glasses, the way the left and right eye images to observe. This technique of creating cool 3D image does not require glasses, but still produces an illusion of 3D. <br /> <p><br /> <p>Instead of two images and combine them into one image with each highlighted in red and blue or cyan and magenta, or a different color for anaglyph images, both images are animated and "wiggle" back and forth, which creates the illusion of depth. <br /> <p><br /> <p>All you need to move a stereoscopic image becomes two pictures taken from a location about four inches apart or more for the positioning of the human eye to follow. You can combine images into one, the more traditional way would be to create an animation GIF file you may use GifNinja it is a Web based application to convert photos and videos to Gif animations.Go to gifninja.com<br />
on Aug 08, 2011 | Cameras
Tip
How to create motion across the screen?
Step 1
Create a small circle to the left in the Stage area. Do this by selecting the circle tool from the left toolbar. Draw the circle in the Stage area.
Step 2
Select the Arrow tool from the left toolbar. Double-click on the circle to select it.
Step 3
Now we have to convert the circle to a symbol. When the circle is converted to a symbol we can create instances of the circle. From the top menu choose Modify > Convert to Symbol. Name the symbol "Ball", and select OK.
Step 4
Go to Frame 10 in the Timeline. Do this by clicking the gray field below 10. Then right click in this field. Choose Insert Keyframe. Keyframes appear as circles in a frame. This operation duplicates the image.
Note: A keyframe specifies changes in an animation. You create keyframes at important points in the Timeline and let Flash create the frames in between.
Step 5
Select the circle and move it to the right a couple of inches.
Step 6
Click on the Timeline any place between Frame 1 and Frame 10. Then right click and choose Create Motion Tween.
Step 7
Choose Control > Test Movie from the top menu to test your Flash movie.
on Aug 11, 2008 | Adobe Flash® CS3 Professional Full Version...
I'm using GIMP to try to create falling snow. The 1st snow image has snow covering the image, the 2nd has the snow moved down 12.5 pixels, the 3rd has the snow moved down another 12.5 pixels, etc. until I...
How are you playing it? are you trying to create an animated gif?
If so, do the following:-
Create a file, with each of your snow images as layers, then
File-> Save As.
Name the image, then go to "Select File Type."
Make it a .gif image, and then click save.
GIMP gives you the option of flattening it or creating an animated gif. Click the button that says "Save as Animation", and then click export.
Then you get to alter a few more variables in the next dialog box (- you can set the frame rate (a higher number makes the animation go faster) )
Then once saved, load it up in an internet browser, and it should work.
Once you've saved you're gif image, open it up in your image viewer. If your normal image viewer doesn't show the animation, try opening it in Firefox or Internet Explorer. You can do this by right clicking on the file, and selecting "Open With." Then choose your internet browser, and you're all set!
Dec 31, 2010 | GIMP
Animations & vedio clips didn't play in web sites internet flash
Hi there, I think I can help you
When images or animations no longer appear in your browser take the following steps.
The most obvious thing to check is that there are no pop up blockers enabled in either the areas below or your anti-virus or windows firewall program, this might also include any image control programs (manage add-ons) such as “Toggle images.exe” in your browser.
If you are using Internet Explorer go to TOOLS/ OPTIONS/ ADVANCED tab and scroll down to multimedia make sure the animations and pictures boxes are checked.
In Mozilla Firefox you find this area under TOOLS/ OPTIONS/ CONTENT/ check the box that says “Load images automatically”
On to the next step
In Internet Explorer go to VIEW/ ENCODING/ make sure “auto select” is checked and is set for the correct language (Unicode)
Let me know if this works for you
Dec 30, 2008 | Computers & Internet
How to animate a flash character
set four corners image when bosewr is holf image size same
Jul 01, 2008 | Macromedia Flash MX
3d rotation
for 3d animation you need other software than flash, you need 3d animation software
especially if you want the user to controll it, sorry
Sep 21, 2007 | Macromedia Flash MX
Movie clip script problem
hi rananjay is here the link is given bellow ,where you find your solution http://www.actionscript.org/resources/articles/538/1/Creating-a-Scrolling-menu/Page1.html
Sep 16, 2007 | Macromedia Flash MX
Redeye
Red-eye is actually caused by the light from the flash bouncing off the back of the retina and picking up the color red from the blood vessels. To correct this effect, follow these steps: Turn the mode dial to PlayBack Mode (green arrow) and display the image with redeye. Press OK\Menu button. Using the arrow pad, navigate to MODE MENU>EDIT>REDEYE FIX. Press the right arrow key, START will display. Press OK\Menu After {BUSY} bar displays, a screen will display with an option to cancel or save the image. ? If the option [Go] is displayed, press the OK\Menu button. This saves a corrected version of the image. ? If the option CANCEL is displayed, than the camera was unable to correct the image. Press the left arrow key to exit. This correction may not work on all pictures. If you import the original image into Olympus Master software you can also apply the Red-Eye fix located in the Edit menu. This lets you precisely pinpoint the eye area and remove the red. It even lets you remove green or blue, which can occur with animals.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Animal Eyes
I've seen some of those white eyes photos. Some are down right scary. I'm sure you have encountered red-eye when taking flash photos of people. With some animals, it is not red - but white. .... Try to catch the animal looking away from the camera when you take that flash picture. Have someone distract him/her. ............ Fixing Demonic Pet Eyes http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Fwww.myjanee.com%2Ftuts%2Fpeteyes%2Fpeteyes.htm http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Ftlbtlb.com%2Ftlbimages%2Fmax2.html
Aug 31, 2005 | Canon PowerShot SD400 / IXUS 50 Digital...
Macromedia Flash MX Logo
54 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Tony
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
