Question about HP DeskJet 920c InkJet Printer
Ink light blinking hp920c
Put in a new black cartridge, still blinks. color cartridge may run out ink. must i change a new color one even just print black?
  • awt7532 Feb 16, 2009
    I found a trick to make it work. Fill in the color cartridge with 70%(or higher) alcohole, put the cartridges back in the printer and wait for a while. Guest what, it moves back the happy face and works! Since I am only needing black and white printing, this saves me a bunch of $$.
    I found a trick to make it work. Fill in the color cartridge with 70%(or higher) alcohol, put the cartridges back in the printer and wait for a while. Guest what, it moves back the happy face and works! Since I am only needing black and white printing, this saves me a bunch of $$.
    Genius:
  • 2,120 Answers
Yes, sorry to say. The system uses all carts even to print in black.
Posted on Feb 13, 2009
The green power button blinks continuously and the printer will not print any type of job. The last job printed was very clear so I don't think I need a new ink cartridge. The status of the printer shows...
ya u need now inkjet cartridge or ur printers card dead 1st chack put black cartridge in ur printers and color cartridge out then see green light blinks if blinks black cartridge out and color cartridge put in the printers then u know thanls
Jul 03, 2010 | HP DeskJet 3940 InkJet Photo Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
K 7100/7103 cartridge light blinking
Gill:
I have the same problem as Sheillz (Sept.15, 2009)
I have installed a color ink printer and both black and color lights of cartriges are still blinking and I cannot print anything at all. Not even a test page.
Can anybody help me pls?
Sep 15, 2009 | HP OfficeJet K7100 Photo inkJet Printer
Cartridge light blinks
Try cleaning the print head first in the software options on the printer and then lightly with a qtip and alcohol or electronics cleaner. The ink jets sometimes dry up and cause the nozzels to get plugged.
Sep 02, 2009 | HP DeskJet 845c Printer
BLINKING ORANGE LIGHT AND NO PRINTING
I just experienced this with my 920c. I cleaned the contacts in the cartridge holders with alcohol and the problem went away.
Jan 31, 2009 | HP DeskJet 920c InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Black light & print cartridge light is blinking. I changed the black cartridge but did not change the color cartridge cause I never use color. Both are in the printer. Black Light is blinking and...
Unfortuantely , to solve the issue , sadly, yes you will have to replace the empty cartridge to continue to use the printer in a normal fashion. Its a sneaky and dirty trick many printer manufactuers do to make more money off of the customer through the purchase of printer ink.
Aug 25, 2008 | HP Computers & Internet
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
HP DeskJet 920c InkJet Printer Logo
356 people viewed this question
Seeker5211
Seeker5211
