Question about Cambridge Audio DVD89 DVD Player
Occasional and very slight "flicker"
On some DVD's, say 50%, there is a almost unnoticeable "flicker" of pause in the video playback on my CA DVD89.
It is only slight, seems to be random and can be from say 5 to 50 seconds apart. Most people don't seem to notice it unless it is pointed out to them.
Possible layer transition? Audio sync?? Monitor compatability???
Repair agent can't fault.
Anyone else experienced this?
Any help on a solution appreciated.
How do I transferre my videos onto my pc to record them on dvd
  1. Plug fire wire into computer.
  2. Plug fire wire into Camera. If camera does not have fire wire you will have to use usb cable instead off fire wire.
  3. Turn camera on set to VCR/Playback mode.
  4. Most cameras will be controlled by computer edit / capture software.
  5. Start editing / capture software.
  6. If camera is controlled by computer click to capture footage.
  7. If no control rewind fotage at camera start playback Then pause playback. Start capture in software then release pause on camera.
  8. Wait for end of footage Turn Camera off .
  9. Edit footage.
Feb 16, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Toshiba D-VR610KU recorded disc won't play in my Daewoo DVD5800
What are the compatible types of DVD's that the Daewoo DVD5800 player is supposed to play? Is DVD-R among the compatible types? Try playing the new recordings on a computer that has a DVD drive, or a friend's computer.
Apr 20, 2017 | Televison & Video
No disk error
If cleaning with a cleaner disk and solution did not work, then you have to clean the lens directly.
Remove the cover and access the inside of the DVD, unplug power first.
Use soft cotton sticks and isopropyil alcohol to clean the lens, here is a picture of the lens pickup:
As usual do the job at your risk, if you want to call for repair you can use the number listed in the owner manual.
Oct 14, 2008 | Cambridge Audio DVD89 DVD Player
In Playback, sudden pause and jump to another scene
Got the same problem. The finalised disc plays correct on some dvd players, but not on my pc with Vista. Can't work with the recordings in pinnacle... Have not found a solution yet...
Mar 15, 2008 | Canon DC40 DVD Camcorder
Pause/video freeze between shots
If the disc is an RW disc with previously written data on it, you'll be asked to confirm whether or not it can be overwritten.after erasing pls use it and try it ,
if you are using fresh blanck Sony DVD-R disk, a Verbatim DVD-R disk and a Maxell DVD-RW disk (all 4.7GB single-sided). no proble but if there is maxell i cant say anything if ther is carry on this problem is not repairable bcoz One of the common problems with HDD recording systems is that they can sometimes (but not always) produce a slight pause at the end of a clip prior to the start of a new clip.
just keep it up.
Jan 11, 2008 | JVC Everio Share Station DVD Burner Burner
Pauses during playback on home dvd player
Im using Verbatim discs and they work fine... try those
Jan 05, 2008 | Canon DC210 DVD Camcorder
Pauses when playback
press the pause buttona gain and it shuld play
Aug 29, 2007 | Canon DC210 DVD Camcorder
Playback is slightly distorted picture flickers
get a video head cleaner and clean it...ur head is just a little dirty
Dec 12, 2006 | Samsung SC-D363 Mini DV Digital Camcorder
DVD Player makes a slight "tick,tick" sound during playback
I would certainly take the unit back cause that noise could be the tracking or focus coils making that noise as they are being overdriver. This could cause the unit to fail prematurly. Its not an adjustment that you can do your self, it takes special equipment and disc
Jun 01, 2006 | Panasonic DVD-S29 DVD Player
Video playback is not smooth while playing via USB 1.1
USB1.1 port can generally handle transfer speeds approaching 5.5Mbps between PC and DVD Camcorder. Smooth playback of movies requires 5.5Mbps speeds or above. If the PC you are using has some compatibility issues with the USB driver software, the USB port may drop to speeds below 5.5Mbps causing short pauses during video playback. It is recommended to copy the movie file from the DVD Camcorder to the hard disc drive (HDD) on your PC, then playback the movie from the hard drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Cambridge Audio DVD89 DVD Player Logo
54 people viewed this question
Top Cambridge Audio Televison & Video Experts
Electro Med Services...
Are you a Cambridge Audio Televison and Video Expert? Answer questions, earn points and help others
