Question about Haier Washing Machines
Haier- xqb50-7288a do you have english version of this model? the water supply is so low that it takes us time to finish washing.
Washing machine says E2 what is problem will not spin
Posted on Mar 29, 2011
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Haier HLP23E - When I press start, the water flows in and out at the same time.
Hi Lina, accordin to the Haier website, E4 stands for "water inlet problem. Water can not inlet or cannot reach the selected level in a proper time.". Unless the ingoing water pressure is really low, I think you need to service the machine. Anyway, hope this helps!
Dec 13, 2014 | Haier HLP23E Top Load Washer
Haier HLP21N washer won't fill. Water runs right through from the faucet to the drain hose.
Is the hose in the sink or on the floor? If in the sink, it sounds like the pump is running all the time. If the hose is too low, it maybe syphoning out the water as fast as its going in.
Nov 08, 2013 | Haier Washing Machines
A drainage problem with my haier w/d
A service manual in English may not be an easy thing to locate as most are Chinese. They are a pretty basic machine, If there is a draining issue it's most likely the drain pump has failed as these are of low quality and frequently need replacing.
Mar 11, 2012 | Haier Washing Machines
Haier washing machine taking water in and taking water out but not spining it gave burning smell once after that stopped spining
From the limited information you provided, I would concentrate on the transmission. Most are a two speed transmission - low for wash cycle and high for spin. If it isn't doing either, you should make sure that it is getting a signal to the transmission from the control board.
Jun 23, 2011 | Washing Machines
Washer showing error 1
on my moms washing machine e-1 means low water pressure. make sure nobody accidentally turned off the water supply, also check that there is actually water coming out of the hoses, where i live its cold right now and if its cold there maybe that portion of you plumbing is froze
Jan 19, 2011 | Haier Washing Machines
SIR I WANT TO OPEN THE SIM LOCK OF HAIER HC-C2076 TO USE OTHER OPERATES SIM
unlock-c2076mv03c
but vahi unlock hoga jo *#0000# karne par version show kar
Selected Model...C2076
Asking Server Access Take Few Seconds...
Successed to connect server
User name...xxxxxxxxxxxxxx
Searching Phone Please Wait :
Your Phone Version:= Dec 09 200914:17:22May 06 200807:00:00SCNGZ355*
Found Inside Version = QSC6010-SCNGZ-3550®?~
Phone Is In Boot Mode.
Prepairing Phone For Opration.
Phone Ready To Unlock..
DATE CONFIRM HC2076MT03C...
SEARCHING INTERNAL VERSION...
Found...HA2076MV03C
SEARCHING LOCKS...
LOCKS DISABLED...
Haier C2076 Unlocking Finish Restarted Phone...
error 0 in comm
error 1 in comm
error 2 in comm
error 3 in comm
Total Time Take...00:00:34
Log Saved To...C:\Advance Cdma\C2076log_5_1_2010_3_08_49 PM.txt
HOPE THIS WOULD BE HELP FULL .
PLEASE DO RATE ME.
HAPPY NEW YEAR
THANK YOU
Jan 01, 2011 | Alcatel Virgin Mobile ?£30 Text Cellular...
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
WASHING MACHINE DOOR WONT OPEN
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Jun 17, 2009 | Haier Washing Machines
Haier dishwasher
I useto have same problem. For some reason there was water under machine, then i tilted machine, clean water and problem solved. This is built-in dishwasher that is why water acumulates under machine and "leak cut off switch" turn off machine. You can't reset machine while you have water under, machine telling you there is a problem, but Haier wan't put solution on their site - Haier suport is very bad. Sorry for English and hope this help.
Aug 08, 2008 | Haier ESD200 Built-in Dishwasher
Washing Machines Logo
171 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
