Question about Biostar NF325-A7 Motherboard
Hard disk partition
Hi, how can I delete hard disk partition
Tnx
    Scholar:
  • 50 Answers
A warning first: Make sure you don't delete the primary partition; This is the partition that contains your OS, and you can cause yourself much grief trying to delete it(Generally, this is the "C:" partition.
So, to delete a partition, there are a number of things you can do; I would recommend using Partition Magic, or a similar program - less margin for error, and much less complicated than other methods.
You can also use MMC, or Microsoft Management Console.
Click Start>Run type in mmc, hit enter. At the Console1 screen, click File>Add/Remove Snap-In.
Click Add.
Scroll down to Disk Management, highlight it, click Add, Finish, Close, and Okay. This will bring you back to the Console1 window.
Highlight Disk Management(Local) on the left, and your drives/partitions should display on the right.
Right-Click the partition you want to delete, and select Delete Partition.
Alternatively, if you're installing windows, you'll be given an option to delete partitions at the beginning of the installation.
Posted on Feb 13, 2009
I tried turning my GX60 into a dual-boot and didn't do the partitions right. Sort of put 2 OS in one partition. Now it won't boot and it gives me readings of Drive C: can't be accessed or...
I think that the operating has gone corrupt and needs to be reinstalled. First, make sure that your PC can read the hard disk in BIOS (at boot up, press F2 to enter BIOS and check "Drive Configuration). You should be able to find the hard drive (as well as CD/DVD ROM) here. If not check the hard disk cables etc. At boot up, you may also press F12 for Boot Menu and select the primary hard disk for booting up the PC.
Secondly, boot the PC from CD ROM, Delete the partitions and make fresh partitions for installation of the operating system. You may also add the hard disk of your PC to another PC (as slave) and delete all the partitions from the operating system and make fresh partitions. Place the hard back into your PC and proceed with installation.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 22, 2011 | Dell OPTIPLEX GX60 Motherboard
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
MY BUFFALO EXTERNAL HARD DISK HD PXTU2 IS SHOWING 297 GB UNALLOCATED. I THINK ITS PARTITION IS CORUPPTED
Hi guy,
You can try a partition recovery software to recover your corruptted partition.I have succeed to recover deleted partition with Tenorshare data recovery.It can recover deleted,formatted,corruptted partition after deeply scanning your hard drive to look for lost data.
Anyway,you can download a trial version and scan your hard drive for free to check out whether your partition can be recovered. http://www.any-data-recovery.com/index.htm
Jun 18, 2011 | Computers & Internet
I want to remove my patition
Perform the following steps which dddriver mentioned
But deleting partition means that your data will be lost from that volume.Its better take the backup of data otherwise your data get lost. To retrieved your data from deleted partition with the help of partition recovery tools. These tools are absolutely safe on the data in the drive and their only concern is to get back the lost data without altering the format.
Jun 13, 2011 | Computers & Internet
Show a step by step procedure to how to reformat a hard disc
- if the hard disk is inside the system use your operating system disk
- boot to the disk by pressing F12
- if you see "press any key to boot to disk" hit the spacebar right away
- if your usinf windows XP delete or partion by highlighting the partition and hit "d" to delete
- it will ask you confirmation, hit "L"
- your system will ask you to reformat hard drive
- for win 7 same process
- first delete partition
- click drive advance option to see the delete option
- delete all partition
- click reformat
hope I answer your question step by step
Jun 07, 2011 | Computers & Internet
How to re-join two partitions on one external hard drive?
You cannot. You delete both and then make one partition.
There is software available that will let you resize a partition. (E.g. Acronis Disk Director). In this case you delete one partition and the resize the remaining partition to use the space created.
Most important: Back your data up to another hard disk before making any changes to your disk.
If this helps please vote for my solution.
Oct 01, 2010 | Verbatim External, USB 2.0, 750GB...
I want to replace vista with xp, but When I tried to install os it is booting from cd but it is not recognising harddisk
its because of sata hard disk
you have to download sata driver from the website
and copy in to one floppy
connect floppy in to the computer
during boot from the cd
press f6
select which version
follow installation steps
Nov 01, 2009 | Compaq Presario C700T Notebook
Biostar NF325-A7 Motherboard Logo
110 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
