Question about Toshiba CF27H50 TV
Toshiba CF27H50 cannot switch from TV to Cable
Satellite system was down for a few days, so I had the TV switched to TV instead of cable so I could wathc local programming. Now the sat is back on line, but I cannot get the TV to switch back to Cable setting. Neither the remote nor the front panel controls will work to do this. I can scroll thru the menu items and move up or down, but not sideways. I thought it was the remote, but it won' t work with the fron panel controls either. Any suggestions?
  • mulder75 Feb 13, 2009
    Has a switch for this, not buttons. But, I discovered I had set the TV to channel 4 instead of 3. Once I switched the channel, it switched over automatically. Everything fine now.
  • 57 Answers
Have you tried pressing the cable or TV buttons on the remote?
I hope this solution is helpful.
Posted on Feb 13, 2009
How can connect toshiba satellite e105 to tv through hdmi cable
you should be able to plug it in directly to the tv with an hdmi cable, and press the Windows Key + P to switch displays to Duplicate or extend to your TV http://res1.windows.microsoft.com/resbox/en/windows%207/main/e5ae24f9-5e00-43af-ad62-b098b3cd5284_21.jpg
Jan 29, 2014 | Hi-Capacity Equivalent of TOSHIBA...
I have a Toshiba CF27H50 that just stated losing the picture after about an hour of viewing. After an hour, it starts to flicker and then the picture just is lost and it just goes to black/snow screen and...
This is a common symptom of tuner trouble. A common problem is bad solder connections inside. As the set warms up, small cracks on joints from the tuner circuit board to its metal case can cause the trouble you describe. If you tap on the TV or wiggle the connector where the antenna or cable line goes, the picture will sometimes pop back in if this is the case. It's also possible the tuner has parts that quit working as they warm up. The only way to know for sure is to remove the tuner, check over the connections, repair any that are iffy, and see if the trouble continues. This is not a repair for a do-it-yourselfer, though, because of the soldering involved.
If the trouble isn't bad connections in the tuner, there's not much you can do. I've checked the parts sources I use. The original Toshiba part is no longer available and I haven't found any replacement. If you're using a cable box or other video source, you can keep using the TV just for its AV inputs and not worry about the tuner any more. Otherwise, given repair labor cost and lack of parts, it's probably more economical to replace this TV instead of trying to repair it.
Jul 22, 2011 | Toshiba CF27H50 TV
It wont switch on
try to remove the battery , then press and hold power button for 8 secs. Then insert the power cable instead of battery. Turn it on. If it wont, try to disengage the power cable and insert the battery. If still wont turn on, kindly inform toshiba about this problem and have them fixed immediately. It is either the battery, the cable or the pc unit itself that causes your laptop failure...
Mar 01, 2011 | Toshiba Satellite C655-S5139 Notebook
Do not know why there is no way to hook up a DVD player.
most stores sell both adapters needed to hook up dvd or any type of electronic equipment buy a a/b switch so u can switch from dvd to [cable or satellite] then buy coaxle adapter which has 3 wire hook up to coaxle for tv [rca $10 ] and coaxle wire. connection wire a or b from dvd to adapter and other from a or b to cable/satellite other end of a/ b goes to tv slide switch to watch dvd and slide back for reg tv
Oct 11, 2009 | Toshiba CF19G22 19" TV
I am not able to connect my Toshiba Satellite pro to my Toshiba tv with a vga cable When I power up the laptop, I get the response 'out of range; on the tv screen. What can I do? Thank you
Have you used the keyboard toggle to switch between the laptop screen and the TV?
If you have no then the toggle is as follows>>>>
Hold down the Fn key and look across the F keys for a key that has an icon of a monitor on it and press that.
Make sure you have the VGA cable connected to the laptop and the TV or the switch won't work.
Good luck.
Sep 02, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Changing TV set up to cable from "air"
Try setting tv to channel 3 or channel 4, this should coincide with the back of satellite box (a little black switch with a 3 or 4). then switch channels with your satellite box. I would recommend using another output off the satellite box to feed the other tv, a splitter loses some signal quality an can go bad as well. get a long rca cable to feed tv!
Mar 01, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I need help! Our cable jack on our tv is messed up so we have to run it through a dvd/vhs player. I have tried everything to get it to work. I can play dvds and see them, but i cant get the satellite to...
Change the source on the Philips/Magnavox to switch between satellite and movies (warning: this particular Philips/Mag cannot process HD Satellite receiver boxes). You can switch sources by using the Magnavox remote and pressing 0-2. Then press ch down until the display says either L1 or L2 - whichever input the satellite is connected to. Another warning: For my instructions to work, you must have a non-HD satellite receiver, and you must run a red, white and yellow cable from the satellite box to the Magnavox instead of a standard coaxial cable wire (and then, of course, run a second set of red, white and yellow cables from the Magnavox to your TV).
-Tha Mp3 Doctor
Dec 31, 2008 | Philips Magnavox DVD/VCR Dual Player
Is this tv set up for the digital switch in Feb.
If the TV was manufactured in 1993, it is NOT ready for the digital switch. If you have cable or satellite, you don't need to do anything because the cable or satellite box will do the swith for you. If you are using an outside antenna (rabbit ears) you will need to get a converter box. Hope this answers your question
Dec 21, 2008 | Toshiba 32AF43 32" TV
Televison & Video Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
