Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Acer LCD AL1916W
Moniter stays on for a while then cut out but power is still on>
    Scholar:
  • 50 Answers
This usually means the Power Inverter board is going bad. If you're a bit savvy with tech repair, you can look up and order a replacement board - LCD inverters for MANY LCD models are available on ebay and amazon - they're relatively easy to replace. Just make sure the power is UNPLUGGED before to start taking apart the display!
Posted on Feb 13, 2009
Moniter won't come on
The problem is in the power supply board often caused by one or two capacitors that open, some will show a bulge at the top making it easy to spot.
Mar 23, 2012 | Acer AL1916W 19" WideScreen LCD Monitor
I have an Acer AL1916W monitor which powers up and shows the Acer logo and then cuts off. It seems to do this when on for long periods.
Please inspect the DC filter caps in the power supply, see failed ACER due to bad caps first.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Aug 31, 2010 | Acer AL1916W 19" LCD Monitor
Moniter displays for few seconds then goes blank
Look for bad DC filter caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jul 03, 2010 | Acer AL1916W 19" LCD Monitor
How do you hook up sound to the computer. I have
The ACER AL1916W does not have built-in speakers, you need to get powered speaker system for your PC.
This is the spec of the AL1916W: http://reviews.cnet.com/lcd-monitors/acer-al1916w-lcd-display/4507-3174_7-31652355.html?tag=mncolBtm;rnav
Mar 30, 2010 | Acer AL1916W 19" LCD Monitor
The Acer monitor's horizontal and vertical is set
use the function button on your moniter and scroll until you see the setting you want to change and increase it or decrese it from there.
Jul 16, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor '' no power''
I'm having the same problem and it turns out to be the main board.This Service guide is for Version 1.0 but turned out to be helpful
http://www.abcelectronique.com/forum/attachment.php?attachmentid=12292
Feb 28, 2008 | Acer AL1916W 19" LCD Monitor
Moniter turns on for 2 seconds turns off
hi guys, first run the system in safe mode, and with vga mode, see if it is the same problem ?? let me know
Dec 30, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Blacking out
This is not a setting or driver issue! The best way to determine this is to connect the monitor up to another device to see if the same thing occurs! If it does then your backlight is in bad shape and it is starting to go bad. It will generate enough power to display some images, but when it continues to be on for a certain peirod of time it goes black. This is common when the backlight is starting to go bad!
Oct 04, 2007 | Acer AL1916W 19" LCD Monitor
Black outs
May be your IP board is going out. Replace IP board.
Aug 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
131 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
