Question about HTC Touch Diamond Smartphone
My htc touch diamond shows the current messages on home screen, i want to turn it off, how can i do
  • Anonymous Mar 30, 2009
    how to change the password for email
  • 32 Answers
Disable the SMS "message sent" popup
HKLM\SOFTWARE\Microsoft\Inbox
create a new key "Settings"
create a new string value "SMSNoSentMsg" and set the value to 1
Thats it your done just give it two minutes and do not reset the phone after finishing
Posted on Feb 13, 2009
My phone is showing a sign
It's a data usage message. Going over your data. Or a failed download or message etc. Pull down notification bar by touching the top of the screen and pulling down. Should show up on the screen why there's a triangle.
Feb 01, 2014 | HTC Google G1/Dream Cell Phone Black...
I have dropped my htc diamond (sprint) and the screen does not turn on.
I don't know if this is the same problem I had, but I think it is. I dropped my HTC Touch Diamond (standard version) yesterday and when I turned it on the screen didn't show anything.
I took it apart and found out the problem was caused by loose connectors between the main-board and the lcm- and navi-board.
The main board (green rectangle marks the problematic connectors):
Which connect to (green rectangle):
Hope this helps.
Kind regards,
ScHAmPi.
Jun 26, 2010 | HTC Touch Diamond Smartphone
I HAVE A HTC TOUCH DIAMOND. WHEN I TURN IT ON IT DOES NOT START UP IN PHONE MODE. THE SCREEN COMES UP WITH A RED,GREEN,BLUE AND WHITE BANDED SCREEN WITH DIAM130 64M SPL-1.38.0000 MICROP-DIAM (LED) V11 IN...
Looks like you should try to Hard Reset it.
This is done by having your HTC Diamond turned off first.
Then, hold the VOLUME UP and DOWN buttons at the same time and briefly press the POWER BUTTON.
Now keep holding down the VOLUME UP and DOWN buttons until you see a screen
At soon as you see this screen, you should release the VOLUME UP and DOWN buttons.
Now press the VOLUME UP button to complete the hard reset. Now this will completely format your HTC Touch Diamond as if it was turned on for the first time from the box. Everything once previously on the phone will be deleted including messages, contacts, music and the like. Hope I have been of assistance to you, Cheers :)
Apr 23, 2010 | HTC Touch Diamond Smartphone
Trying to get screen to turn when texting HTC touch diamond
Unfortunately the gyro in the HTC diamond only operates in certain programs like opera mobile internet browser, when viewing pictures in album, and the game teeter. The keyboard would be bigger if it could be rotated using the gyro but HTC did not program it to do this. There are some free program you can download that will allow you to do this but they also rotate everything else every time you tilt the phone.
Dec 28, 2009 | HTC Touch Diamond Smartphone
My HTC Diamond Touch Screen wont work
you can try to recalibrate the touch screen to see if that works,
Start> settings> display> calibrate
* since screen is not working you will have to go the long away and use buttons on phone and nav wheel to get to these options
Jun 17, 2009 | HTC Touch Diamond Smartphone
I want to make the "time" smaller on my home screen
Try sweeping your thumb upwards on the clock this should drop the larger boxes back and bring up a smaller clock. It worked on my HTC Touch Diamond hope it helps
Jun 12, 2009 | HTC Touch Diamond Smartphone
My htc touch diamond shows the current messages on home screen, i want to turn it off, how can i do that.
download Advance configeration software or Diamond tweek software from freewarepocketpc.com. this software having that solution.
Feb 13, 2009 | HTC Touch Diamond Smartphone
Incorrect time showing on face clock
in that case... remeber to set your phone into an automatic time and date update. You can find it on the settings menu and there goes.. its done.
Feb 01, 2009 | HTC Touch Diamond Smartphone
HTC Touch Diamond problems with Manila.exe, Shell32.exe, reboot
May be this is because of using older ROM's i.e firmware..
Goto HTC site and find the updated ROM for ur device..
Current version of ROM's may have fix for ur problems...
Take backup of ur data before updating the firmware....
Thanks,
Jegan..
Dec 11, 2008 | HTC Touch Diamond Smartphone
Hard reset for a HTC Touch Diamond
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
2. On the System tab, tap Clear Storage.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
HTC Touch Diamond Smartphone Logo
117 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
