Question about Panasonic NN-C994S Convection/Microwave Oven
NNC2000P - Microwave does not work but convection works
We have a NN C2000P oven which was repaired in Sep. 2008.
The Panasonic guys replaced the magnetron and IGBT's.
Within a few months, the following problem is observed. When in heating mode, after about 8 second, a tick tick sound is heard and the oven shuts down.
However, the convection features work all right.
Please help.
  • 2 more comments
  • milindlk Feb 14, 2009
    Thanks MrMark52.
    The "tick tick sound" is more like snaping.
    I also don't understand the purpose of an IGBT (Induced gate bipolar transistor) in the circuits of the Microwave. Unfortunately I don't have the circuit diagram.
    Thanks again.
  • milindlk Feb 16, 2009
    Thanks Guru.
    1. Yes, the model was purchased in Dubai & is currently in India.
    2. Does "Magnetron" and "Inverter" mean the same part?
  • Mark Egan May 11, 2010
    If your good to work on equipment like this, I would open it up and see what's ticking. You'll also probably find the wiring diagram, which may explain what the IGBT is for.
    Let us know what you find. But I caution you, stay clear of the wiring. There are very high voltages present (up to 3KV.).
    Sounds like a high voltage problem in the magnetron high voltage circuit, if the ticking sounds are more of a snap/pop.
    For some reason, my mind is not letting me figure out what the IGBT is to know if it might be related.
    I would take it back to where you had it fixed and discuss the short life of the repair. Be reasonable, if something else failed to cause the problem, don't make it an issue that ti should have been caught the first time around. Just be sure the repairs are covered under a new repair warranty as well. But above all, be reasonable in your discussions.
  • Panasonic Master
  • 9,098 Answers
An IGBT is an insulated gate bipolar transistor - sort of a hybird between a bipolar transistor and a MOSFET.
These are the final output driver transistors in the high-voltage inverter.
If it stops after 7 seconds, it still has a problem with the inverter.
It's likely a bad transistor, an electrolytic capacitor with an internal short or bad ESR or altered value, bad connection on the inverter board, a shorted diode or blown resistor, or a bad connection in the wiring.
Reputable service centers will have a repair warranty, but it may only be 30-90 days.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You should use a Panasonic-authorized service center so they'll have the service manual and (hopefully) experience and training to repair inverters.
In the US, you can find an authorized Panasonic servicer here.
This sounds like a non-US model. If so, visit panasonic.net, find your home country, then find the service / support links.
Posted on Feb 15, 2009
  • William Miller
    William Miller Feb 23, 2009
    The magnetron and inverter are not the same.
    The inverter is a circuit board which converts mains voltage to high voltage.
    The magnetron is the finned metal device which outputs microwave energy and is fed its high voltage by the inverter.
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
What is the output power of National NN-C2000P microwave oven?
the pwr rating is normally on the label.
google for a manual
Feb 02, 2016 | Microwave Ovens
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
Dimension 4
I have this NN-C780P Microwave/Convection Oven. The microwave mode is not working and baking was ok until recently, the turntable cannot rotate when the temperature, timing and baking are ok.
When I bake, there are knocking sound.
Please advise.
Sep 10, 2013 | Panasonic NN-T888S Convection/Microwave...
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
My micro oven NN-C2000P No lcd light display even the 240 v suppy is going in the Power supply panel. the door is totally close.
IS GREEN LIGHT IS ON BEHIND LCD ? ANY LCD NEEDS BACKLIGHT TO DISPLAY. JUST LOOK OUT FOR FUSED BACKLIGHT. LET THE DOOR OPEN OR CLOSE THE DISPLAY SHOULD BE ON.
Apr 01, 2010 | Panasonic NN-T551 Microwave Oven
Our NN-8500/NN-8501V Micro/Convection is no longer repairable
hi Peggi and john, have a look here for repairs and new in Dallas TX area:
http://www.superpages.com/bp/Dallas-TX/Affordable-Appliance-Repair-L2069127442.htm?SRC=portals&C=Range+%26+Oven+Sales+%26+Service&lbp=1
regards from the UK :)
Nov 21, 2008 | Panasonic NN-T888S Convection/Microwave...
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-C994S Convection/Microwave Oven Logo
540 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
