Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
I have a model 536886260 craftsman snow thrower,belts slip off
I bought this used and have only used it once before , I think the shear pin snapped and I think that the belts are worn and need to be replaced. They or one has slipped off once before.I am a female, who is willing to try and fix anything, but I don't have the owners manual and I don't know where or which type of belts to get. Do I get them only from Sears or can I get them at Autozone?My husband travels and is out of town frequently, so I would like to fix it before this storm comes over the next few days.Can anyone help me find the parts?and possibly walk me through replacing them?
Thanks,
deadnthesnow
  • mamashanayna Feb 14, 2009
    I have the manual, but the parts were out of stock today and I need them yesterday. Sears is not reasonablly priced for me. I live in a remote area and it will be weeks before they could get me an appointment. I did go to autozone and I will need to bring the belts with me tomorrow.Note also the part numbers in the manual are only from Sears.When I called sears parts they couldn't even tell me what sizes the belts were or what type of shear pins to get, basically no help from Sears.Thanks for your help, I'll be replaceing the belts tomorrow.
    Mamashanaynay
2 Suggested Answers
SOURCE: craftsman snowthrower will not throw snow
I have the same machine and it sounds like the belt is indeed slipping.  If the belt is not worn or stretched too badly, you can perform a small adjustment on the idler-wheel (the thing that controls belt tension) by sliding back the plastic cover on the spring that is attached to the bottom of the lever-cable and tightening the nut so that there is less slack in the cable.  If the nut is all already all the up, then you need to replace the belt, which can be easily accessed by removing the plastic cover in front of the motor under where the spare shear pin compartment is located.  There are two bolts (one on each side) that need to be removed and then the cover just pulls off.  This will expose both belts.  The front one is for the auger drive and the rear one is for the wheel drive.  The belt can be easily replaced without any further dis-assembly by simply removing and replacing it in the reverse manner.  Don't forget to readjust the spring so that excessive tension is not applied to the new belt.  Hope this helps.
Posted on Jan 20, 2009
PB30 - 96025000300 (2011-01)
Check Belts as well as the shear pins in your pulleys .if the pulley turns but does not drive I suspect a shear pin has sheared off and needs replacing. The shear pin is inside the pulley and you need to remove the pulley to get to the pin.
Jun 23, 2016 | Garden
While mowing the drive belt tightner spring broke. I bought a replacement but the blades will not engage. The drive belt has been routed properly. it seems as though the blade's drive shaft will not spin.
Check and see if the shear pin has broken. If the pulleys spin but not the blades then the shear pin in the pulley or shaft has broken.
Mar 30, 2015 | Garden
I just replaced a shear pin on my craftsman snowblower and now the auger will no turn when handle is engaged
maybe there ias damage to the gears in the center piece. is the fan that blows the snow out turning?
Feb 07, 2015 | Craftsman Garden
Reach/remove pin.
Patricia, I am not sure which model you have old or new. I have the old one built in the 30's. I had to replace the shear pin and the carbon brushes for the motor. I took the bottom off which has a ball bearing resting loosely in a cavity in the bottom plate. Don't lose it. Now the brushes I found at an ace hardware. Take the old ones to compare. I think there was a bracket holding the brushes and rotor in. Once the rotor was out you could get the brushes out. Putting the brushes in required figuring out how to keep the brushes retracted. I used a piece of paper and used it hold them back while sliding in the rotor. Once in pull the paper out.
Now the shear pin needs to be in to prevent damage to the grinder in case what you are grinding has something too hard to grind like a small rock, I think if you push up on the rotor when the bottom plate is off or pulling up on the shaft it might give enough clearance to put the shear pin in. It sits very close to the bottom of the shaft so it can be fun trying to line it up. I used needle nose pliers to hold the pin just right while pulling up on the shaft. I bought the shear pin off of ebay
Mar 31, 2014 | KitchenAid A-9 Electric Burr Grinder
PTO not working
You have snapped the shear pin that is in the drive pulley. You have to remove the pulley that spins on it's shaft off and put a new shear pin into it. I have replaced several myself. The shear pin is a protection to prevent costly breaks.
Nov 12, 2017 | Garden
Husqvarna shear pins break within minutes
if we are speaking about the shear pins on the tines, the ground is the problem and you need to begin your first pass on a more shallow setting and progress to a deeper setting gradually. if we are speaking about the shear pins on the tires w/o engaging the tines then these should not be breaking and I recommend that the tiller be examined by an authorized dealer.
Jun 15, 2012 | Husqvarna Garden
I have a 5/22 2 stage MTD snowthrower and from behing the machine, the right side auger is not spinning. The left side works fine, when the engine is off, the right side spins freely while the left is...
your shear pin(s) are broken on that side they will look o.k. but are snapped off inside drive them out with a large nail or center-punch,don't use a regular bolt to replace the shear pin as they will fit,because if it gets plugged again the gearbox will be your next expensive shear pin to replace
Feb 24, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Tines don't turn
There is usuall a shear pin on the shaft so that when it hits something serious it will shear off preventing the engine from being ruined. I would look for a shear pin somewhere.
Mar 28, 2009 | Garden
Kenwood chef
I think your toothed belt is gone and have to be replaced.
Nov 29, 2007 | Food Mixers
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
568 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
