Question about Microsoft Windows Vista Ultimate Edition
Vista boots and loads to a black screen and cursor
Command prompt will not load
safe mode does not work.
chkdsk does not work
system restore does not work
Editing rpss in registry does not work
VGA mode does not work
  • 1 more comment
  • brettwilliam Feb 14, 2009
    The pc boots fine. But does not attempt to load the desktop environment. I can hear sticky keys being turned on but all I see is a blank desktop.
    I backed up the data to an external drive and reinstalled the os but this is not the solution I was looking for.
  • Vanja Djuric
    Vanja Djuric May 11, 2010
    so, you can not start your pc at all? what did you do that coused this?
    Genius:
  • 1,605 Answers
Solution 1). reinstall operating system
solution 2). see solution 1
Posted on Feb 13, 2009
BIOHD-s no drives detected
Error Code Biohd-2 No Drives Detected errors are caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
If you are unable to get a connection with your hatd drive
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
You might have to use safe mode with Networking to download
Select safe mode with Networking to download
Oct 07, 2013 | HP Computers & Internet
Windows cannot find
will the computer boot to an operating system ?
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
If this fails you might use the system restore option
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Jun 07, 2013 | Computers & Internet
Gateway dx4710-05 will not start upgoes to repair , will not repair
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Gateway DX4710-05 PC Desktop
Acer aspire ast180-ud400
You have no stated what sort of problem?
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Acer Aspire™ T180 PC Desktop
Nls error
Step 1:
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 21, 2013 | Acer Aspire One PC Notebook
I have an HP notebook. I was on Skype with a friend when suddenly it froze showing green colors on the screen. Nothing would un freeze it so I opted to turn it off through the power button. ...
Step 1:
Enable VGA mode
Reboot
Feb 11, 2013 | Computers & Internet
Recovery 32 type mismatch message
Step 1:
Enable VGA mode
Reboot
Feb 03, 2013 | Acer Aspire 4720 Notebook
\Windows\System32\Config\
Is there anything else on the error message ?
Which operating system ?
Enable VGA mode
Reboot
Jan 28, 2013 | HP Computers & Internet
Pc will not let me run on safe mode it will automatically shut down
in such case 3 things can be done:
first thing
1- boot from windows installation cd ,
2-press R when prompt for recovery console , you will have a command prompt screen
3-type this command and wait till finish : chkdsk /p or chkdsk /f
4-when finished eject cd and type : exit
you will have the pc rebooted
if the pc does not work try this
second thing is replacing your corrupted registry files with older working one from system restore files:
http://www.winhelponline.com/blog/restore-registry-hives-system-restore-snapshot-xp/
the last thing you can do:
is to boot from windows cd and reinstall windows with option "repair windows"
Feb 08, 2012 | Dell Dimension C521 PC Desktop
No programs, no buttons work, mouse works, starts but thats it
Restart and keep pressing F8 key. Select safe mode option. IF it will boot into safe mode ok then go to start->all programs->Accessories->system tools->system restore. REstore computer back to previous date.
If this will not be possible.Restart and keep pressing F8 key and select safe mode with command prompt. In command prompt window type in "chkdsk /r " this will run checkdisk and restore missing files.
Please leave your feedback if issue was solved
May 27, 2009 | Dell Inspiron B130 Notebook
Microsoft Windows Vista Ultimate Edition Logo
101 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
