Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
I accidentally plug in my sharp aquios 110v to 220 v
I was able to get some help from friend technician but accdng to him the parts that we need to replace is not yet available in the market
    President:
  • 1,077 Answers
If your TV is a LC-42D62U like it says on the post, there seems to be plenty of parts at shopjimmy.com
What part does he need to replace?
Posted on Feb 13, 2009
My charger is accidentaly connect into 220v and this is burn. im here in philippine. its this to repair and i use again...
Is this a 110Volt version that you plugged into 220v?
There is a ceramic Fuse inside the unit that might be blown. It is the first thing on the circuit board near the power cord connection.
Open the unit up and post a photo of any burned components ?
Jul 10, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I accidentally plugged my sony 110v to a 220 v outlet. how to fix it?
You cannot fix that unless you're professional, but then you wouldn't be coming here would ya!? :P You probably fried your televisions circuit boards.
Jun 20, 2011 | Televison & Video
My Panasonic S35 DVD player was plugged in to 220 volts instead of 110 volts. The problem is just after replacing two (2) capacitors, diode, and fuse. the unit was accidentally plugged in again to 220...
If the unit is designed to operate at 110V AC, then plugging it into 220V or more without the appropriate multi-current (240-110V) transformer and relative voltage switching circuitry to the PSU (to accommodate the higher current load) is very dangerous. Because of the excess voltage applied, the DVD player's power supply cannot handle this, is basically destroyed, and therefore it would be uneconomical/expensive to repair; although due to the possible extent of the over-voltage damage, I doubt it would be repairable.
To put it bluntly, the whole unit would be a write-off, as the damage to the power supply may have also compromised many of the components on the motherboard. It wouldn't be cost-effective to replace every single part in the circuit. You most likely will need to buy a new player (or find a similar used working one which is not damaged for a cheaper price if that's what you want) and if you do, check to make sure it is a mulit-system/multi-voltage model (can operate between 110V and 240V AC, and is capable of doing so SAFELY) to prevent a disaster like this from happening in the future.
The risks of electrical incidents like this are far too great to even contemplate. One can be lucky sometimes.
Mar 06, 2011 | Panasonic DVD-S35 DVD Player
How to convert electricity from 110 to 220 volts for my SHARPE Microwave oven
Ah, the problem of the ages. There are 2 solutions. One is a transformer of the proper size, and the second is to purchase a heavy duty battery charger (that runs on 220 volts). Connect the red and black (+ and -) wires to a 12v to 110v voltage inverter, similar to what you would plug into a 12v auto 'cigarette lighter' socket to produce 110v current from a car battery. The charger turns the 220 vac to 12 vdc, and the inverter turns the 12 vdc into 110 vac. This works, as it is what I did when I moved from the US to England.
Feb 04, 2010 | Sharp R-230 Microwave Oven
Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Dec 03, 2009 | Craftsman Saws
Accindentally pluged it to 220 volts instead of 110 volts
hello , i suggets you replace the power supply with a 110 v input boerd .
or do this if the damage is big replace the all sytem with a new one then get a voltage step down ie 220 to 110.
thank you
May 06, 2009 | Yamaha DVR-S120 DVD Player
I have plugged wii in 220 volt recepatacle though it was 110 volt what to do
There are two possible scenario's when you accidentally plug a 110V device in a 220V outlet:
1: The power supply to the device you plug in gets fried. this is your best case scenario. See if you can borrow a Wii power supply from a friend and test your console with this power supply. If this works, you just need a new power supply and all is well.
2. Your Wii gets fried. Worst case scenario: your Wii got fried. If it is still in warranty, see if they will cover this damage under the manufacturer warranty, if not, I am afraid you will either need to pay for repairs or buy a new console.
I hate to be the bearer of bad news, but plugging a 110V device in a 220V outlet generally will fry one thing or the other or even both.
Thanks for using the FixYa forums!
Mar 29, 2009 | Nintendo Video Game Consoles & Games
Sharp aquios 32"
unplug the tv from the power outlet, wait until the light stops flashing then plug it back in. works for me.
the flashing light means that your tv needs to be serviced, if its still under warranty you shouldnt have to pay for this.
-w
Nov 17, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
119 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
