Question about Maytag MGR5751AD Gas Kitchen Range
Maytag Gas Range.. Oven comes on then goes out in 20 seconds
Oven comes on then goes out in 20 seconds. The ignitor is working because it does light. I hear a sputtering then it a very weak flame for about 5 seconds. Poof, out again. Repeat.. The broiler works fine.
    Novelist:
  • 117 Answers
Sures sounds like the ignitor is causing all the problem. Simply becasue the ignitor is lighting does not mean it is good. Your unit incorporates a flat style ignitor and it must draw 3.2 - 3.6 amps in order to fully open the oven safety valve. There are only two ways to verify this. The first and more professional way is to measure the amperage draw of the ignitor after it has been glowing for approximately 45 seconds. I feel certain you will fnd the draw 3.2 amps or lower. The second would be to make an intelligent guess and order part number 74007498 which is an ignitor for your oven. If we can help further feel free to respond.
Waiting to hear from you,
Eric Campion
Posted on Feb 13, 2009
Stove top works , oven does not
If the ignitor is not glowing to lite the oven then it needs to be replaced. Here is that part to order.
Whirlpool 74007498 Oven Ignitor AppliancePartsPros com
Mar 20, 2014 | Maytag MGR4452BDW / MGR4452BDQ /...
My Maytag gas oven will not come on. Range eyes will work so gas is coming to range.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 21, 2011 | Maytag Kitchen Ranges
Our Maytag oven, the ignitor works, but no gas comes through. The broiler works and the top range works. So what can be the problem?
On a silicone carbide ignition system, the design is simple. The ignitor glows and changes the resistance in the circuit. When the resistance is right the gas valve will open and you will have ignition. So what goes wrong? The ignitor gets weak and no longer opens the safety valve. Here is a video which show how it works:
Dec 02, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
My Maytag Gemini Gas Range works fine as far as the four burners, the bake on the top and bottom oven, but the broiler on the top oven does not work. Is this a pilot issue? I really appreciate the help,...
If the broiler burner is not coming on it may be a bad ignitor or the ignitor may not be getting power. Observe the ignitor when you turn in on ans see if it glows at all. If not then test for power to the ignitor if you have power and not glowing or lighting replace the ignitor. If it glows but does not light the ignitor may just be weak replace it.
Nov 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My Maytag gas range oven is not working. The broiler works okay.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jul 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Bottom oven will not heat up.
Jun 11, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Dec 19, 2007 | Whirlpool SF310PEK Gas Kitchen Range
Maytag MGR5751AD Gas Kitchen Range Logo
310 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
