Question about Acer Aspire 5500 5570-2609 Laptop
Can't access any programs or download or anything on my desktop a
Computer states: Windows could not start because the following file is missing or corrupt: \system32\hal.dll.
Please re-install a copy of the above file.
Submitting this with another computer because can't do absolutely nothing with the Acer. Please Help!!!
  • 458 Answers
If you have a Recovery Partition .. you can access it by powering on while holding the F-10 key... (some models use a different F-key)..There you can restore or recover windows.. If no Partition exists, you will need a windows OS cdrom and boot to it, at the first screen it stops at, press R to get to your Repair Utility Screen.. Choose the Proper Hard Drive Partition From the choices given, and once it gets to the prompt... type fixboot.... when that finishes, type fixmbr... reboot..
Posted on Feb 13, 2009
Cant sign on to computer
    • 1 Download the missing comctl32.dll file. Locate a website that offers the comctl32.dll file. You can also use the link in the Resources section.
    • 2 Unzip the download file if it is a .zip-type file. Right-click on the file and choose "extract" to make the file available in a .dll format.
    • 3 Install the missing comctl32.dll file in the proper folder on the computer. If the operating system is 64-bit Windows, copy comctl32.dll to the "C:\Windows\SysWOW64" folder. If the operating system is 32-bit Windows, copy comctl32.dll to the "C:\Windows\System32" folder.
    • 4 Restart the computer by clicking on the "Start" button and selecting the "Restart Computer" option.
    • 5 Open the computer program that previously displayed the error message stating that the file comctl32.dll was missing. This will verify the program now works properly.
Nov 21, 2011 | Dell Latitude D 600/610
Advrcntr2.dll is missing
CLICK HERE TO DOWNLOAD
To install advrcntr2.dll, follow these instructions:
  • Open the zip-file you downloaded from DLL-files.com.
    • Extract the .dll-file to a location on your computer. We recommend you to unzip the file to the directory of the program that is requesting the file. If that doesn't work, you will have to extract the file to your system directory. By default, this is C:\Windows\System (Windows 95/98/Me), C:\WINNT\System32 (Windows NT/2000), or C:\Windows\System32 (Windows XP, Vista, 7).
    • Make sure overwrite any existing files (but make a backup copy of the original file).
    • Reboot your computer.
    • If the problem still occurs, try the following:
      • 1. Press Start and select Run.
      • 2. Type CMD and press Enter (or if you use Windows ME, type COMMAND).
      • 3. Type regsvr32 "filename".dll and press Enter.
Dec 01, 2010 | Microsoft Windows Vista Home Basic for PC
SysMech.exe Access violation
Please follow the steps below to perform a thorough uninstall and reinstall of your iolo product. Depending on which iolo product(s) you had, some of these items may not be present.
1. First uninstall anything from iolo from your system and restart the computer.
2. Right-click on the Windows Start button and select Explore.
3. Navigate to C:\Program Files and delete the iolo folder.
**If any of these folders state a file is in use, open your Windows Task Manager and end any iolo processes that are running and try again. Ultimately, Windows Safe Mode will allow all of the folders to be removed.
- Starting Windows in Safe Mode
http://www.iolo.com/customercare/kbarticle.aspx?ID=KBA-01932
4. Once the folders are removed, click on the Windows Start button, select Run, in the Open field type REGEDIT and click OK. This will open the registry editor.
5. Navigate to HKEY_CURRENT_USER, Software and delete the iolo key.
6. Navigate to HKEY_LOCAL_MACHINE, Software and delete the iolo key, should it exist.
7. Navigate to HKEY_LOCAL_MACHINE, Software, Microsoft, Windows, CurrentVersion and double-click on Uninstall.
8a. When it expands, look for any of the following items and delete them should they exist:
{BBD3F66B-1180-4785-B679-3F91572CD3B4}_is1
{78E33B36-2103-49FC-B058-8CF44B6E75FD}
System Mechanic_is1
System Mechanic Professional_is1
System Mechanic 6_is1
System Mechanic Professional 6_is1
System Mechanic 7_is1
System Mechanic Professional 7_is1
System Mechanic 8_is1
System Mechanic Professional 8_is1
DriveScrubber 3_is1
8b. Please also delete these two keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ioloSystemService
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ioloFileInfoList
9. Remove residual antivirus files
a. Right-click the task bar located at the bottom of your desktop and select Task Manager.
b. From the Windows Task Manager select the Processes tab.
c. Locate and click on the process named Dvpapi.exe to highlight it.
d. Click the End Process button, then click Yes to confirm.
e. Navigate to C:\program files\common files and right-click the folder named Authentium.
f. Click Delete, then click Yes to confirm.
g. Download and install the Microsoft cleanup utility. You can download this file from Microsoft’s web site at: http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
h. Run the utility by clicking Start>All Programs>Windows Installer Clean Up.
i. Highlight Authentium Antivirus SDK and click Remove. Click OK to confirm.
10. Close all open windows, restart the computer & re-download.
Regards
Apr 22, 2010 | Iolo Technologies System Mechanic: Windows
Dbghelp.dll
Here is a link to the download from Microsoft to fix this. Just download and run this and it will take care of that issue.
http://www.microsoft.com/downloads/details.aspx?FamilyID=cd1fc4b2-0885-47f4-af45-7fd5e14db6c0&DisplayLang=en
Mar 20, 2010 | Dell Inspiron 546 MT PC Desktop
Can`t load cd/dvd`s in my laptop. Clicking on my computer and the drive is not there, any ideas?
This is caused by the upper and lower filter registry in Windows. I've created a link for you. You have to access this link to download the rmvfltr.exe file. Regardless of the laptop brand you have, follow this instruction/s: It will work.
  1. Access this link: http://tiny.cc/49KcC then it'll ask you to run or save. Download and save it to your desktop first. You'll have the RmvFltrs file on your desktop,
  2. For Windows XP, double-click the file RmvFltrs.exe on the Windows Desktop (select unzip) to start the installation program.
    For Windows Vista, right-click the RmvFltrs.exe file, and choose the "Run as Administrator" option. ** If a User Account Control dialog box displays the message, "An unidentified program wants access to your computer", click Allow. (Select unzip if it asks you to do so.)
  3. Follow the onscreen prompts to complete the installation.
  4. Restart the Computer.
    It should work after computer restarts.:)
Nov 24, 2009 | Computers & Internet
Toshiba satellite L40 dvd player will not work. have re-installed dvd player and tried updating driver but nothing is happening
Open your Windows Explorer (My Computer) window. Is the DVD/CD icon there? If it's not there, follow these steps:
  1. Click the following link to download the remove upper/lower filters from the windows registry._ http://tiny.cc/9BV5G (RmvFltrs.exe). Save the file to the Windows Desktop.
    Unzip then,
  2. For Windows XP, double-click the file RmvFltrs.exe on the Windows Desktop to start the installation program.
    For Windows Vista, right-click the RmvFltrs.exe file, and choose the "Run as Administrator" option. If a User Account Control dialog box displays the message, "An unidentified program wants access to your computer", click Allow.
    It should work.
Nov 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Computer will not boot up
This is because of either the system has shutdown while it was processing a windows file. sometimes repairing the OS or running a CHKDSK /R in the recovery console will fix this problem. if that doesnt help i recommend you change your HDD
Sep 16, 2009 | Dell Optiplex 740 Desktop Desktop Computer...
Windows Startup Problem??? Please Help!
This is work for a computer reparer with 'real' tools (e.g. an external DVD drive).
The only thing you could try yourself is removing the harddisk, placing it as a second harddisk in another computer and cleaning it with a program like Malware Bytes Anti Malware.
May 05, 2009 | Dell Dimension E310 PC Desktop
WMI Error
I'm pretty sure you have a failing hard drive. Try dowlnloading diskeeper 2009 trial & see what it shows for fragmentation of the drive. Run the program & defrag the drive. If that doesn't help you can look for a program called tuff test & check the drive that way. That's the sure fire way to find out. If the drive passes tuff test then back up your important stuff & reformat & re-install the os. Use google to find tuff test. Good luck!
May 03, 2009 | Computers & Internet
Our Imedia 1502 when started displayed the following message: Windows could not start because the following file is missing or corrupt \windows\system32\config\system You can attempt to repair thisfile by...
your computer is missing some perticular files so the best way to reinstall OS. u can get OS disc from a person who has same model of desktop. but i am in confusion that this disk works on your desktop because they give some perticular key for every computer.
Mar 24, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
