Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
Bissell Healthy Home Won't turn on
Yesterday I plugged my vacuum in to use and it would not turn on. I tried a lot of outlets and still nothing. I even tried it this morning and it still won't turn on.
  • 4 more comments
  • mjmj57 Feb 22, 2009
    I have checked all of the hoses and connections, cleaned the filters and I still cannot get it to turn on!
  • jennlynn0377 Mar 11, 2009
    Mine won't turn on even though I have tried several outlets and cleaned it out and changed the filter.
  • Anonymous Apr 15, 2009
    The solution #1 worked for me
  • azehner Apr 15, 2009
    I had the same problem! Solution #1 worked for me. Thanks!
  • freelanceang Apr 25, 2009
    I have the same problem. Healthy Home Vacuum won't turn on! Ughhhhh!
  • allison93 May 11, 2009
    My Bissell Healthy Home won't turn on either.  I used it in the garage to clean out my car.  One time it was working fine, the next it wasn't.
I found the solution for my vaccum!!
The top handle connects to the lower half of the handle with one phiilips head screw. The screw is halfway between the cord holder on the back. The screw had come loose and the handle has slid back away making it not make contact to send the power down to the motor.
Hope this helps someone else!
Posted on Apr 12, 2009
  • Wannabe DIYer
    Wannabe DIYer Jun 09, 2015
    I had this exact issue, fixed it in 5 seconds!
Same problem here; brush motor started/stopped as I changed the angle of the handle. Before finding this solution, I had tried bypassing the cut-off switch over the left axle, that turns off the brushes when the handle is perpendicular, but that didn't work. Moving the handle still caused the problem. This connector in the handle solution seems to have solved my problem. Before tightening the screw, I noticed the handle wiggled back and forth easily a the joint due to age/use. And I didn't just tighten the screw, I also took a knife and enlarged the pins and collapsed the sockets of the connector ends to help ensure this didn't happen again for some time. Problem solved, thanks!
Posted on Jan 03, 2010
2 Suggested Answers
SOURCE: Bissell Healthy Home Vacuum
easy fix- mine did this too for a while bfore I figured out the handle wasn't aligning properly where attached. Give it a smack to realign it and it works again
Posted on Jun 08, 2009
Bissell 5770 Brush Issues
Hi their... By touching accidently the screw driver ok circuit board that may be caused of a short of any kind fues on the board or small resistant... Please contact to electronic technician to repair it rather than purchasing new board... Thank you
Oct 24, 2017 | Bissell 5770 Healthy Home Bagless Upright...
Bissell healthy home vacuum roller won't spin
Hi Helen. Your Healthy Home vacuum has a lifetime belt. If the belt needs replacing, you should bring it to one of our Authorized Service Centers for repair. Also, here is quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1394&cid=ccsocial
Here's a quick link to assist you in locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Apr 05, 2013 | Bissell Healthy Home HEPA Bagless Upright...
I plug my vacuum in and turn it on and nothing happens. checked different outlets and still the same problem.
Check the following:
- The handle may not be installed properly, causing a loss in the power connection. Remove the handle completely. Slide the handle back into place on the lower section of handle and tighten the screw.
Jun 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Wont turn on when pluged in and the plugs that
tighten the center screw in the back that holds the top handle assy on. this always comes loose and causes the vacuum to not recieve power. let me know if this doesnt fix the problem
Jan 08, 2010 | Bissell 5770 Healthy Home Bagless Upright...
The motor for brush won't turn on for the bissell healthy home vacum
Is the grey "brush" button on the handle depressed? Brush won't turn unless the button is down
Jan 01, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Brand new Bissell Healthy Home 5770H Upright will not turn on.
If the brush attachment isn't locked into place than the vaccuum will not work make sure it is attached properly.
Jun 18, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Dec 03, 2007 | Vacuums
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
5,286 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
