Question about Sony Playstation 3 (PS3) Console
PS3 does not work in 1080p
I have a 32 inch LG3270. it is capable of 1080p. but when i turn on my ps3, it works fine for a few moments. then suddenly it flickers and the sound goes in and out.
i went into video settings, and told the ps3 to output video thru the HDMI on everything but 1080p. the flickering and audio drop stops. as soon as i turn 1080p back on, the flickering returns.
why would this happen?
  • 52 Answers
My ps3 didn't like a HDMI connection very much. I tried the Composite input cables and they worked great with no screen flicker.
-Captain Jake
Posted on Feb 13, 2009
  • Captain Jake Feb 13, 2009
    is it a plasma tv?
Sony STR-DE925 auto-decode has worked fine for years. All DVD/PS3/Cable is attached to TV via HDMI and inbound audio from HDTV is optical fiber (TOSLINK). Up until today, this has worked perfectly, i.e.,...
OK, so with more troubleshooting, I was able to eliminate the problem with my DE925. It was actually the Vizio HDTV that was causing the problem, as I decided to route the optical audio from my DVD and PS3 directly to the same TOSLINK port on the DE925 and auto-decode worked. It was not the fiber-op cables either. This HDTV was a less-expensive 720p 32" model anyway, so I am not too concerned with the optical out working on it as I can run up to four TOSLINK connections in to the receiver.
Jan 02, 2010 | Sony STR-DE925
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
I have had to change my mainboard on my 1080p and my PS3 won't send a signal to my TV anymore. What is the problem? I have heard that I need to ypdate the firware on my PS3. Is that going to solve the...
If everything works ok except the PS3 on the TV then suspect the PS#. Is there any other device you can plug into the HDMI port if thats what you are using? If they work then the issue is the PS3 and not the TV. Please take a few moments to rate my answer. Thanks..
Nov 19, 2009 | LG 37 in. Flat Panel LCD HDTV
My 42LG50 won't accept the 1080p output from my PS3 Plz help.
Most PS3 games do not support 1080p, so if u have a 1080p supporting game, only then can u do it.
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Hi ..I was wondering if Playstation 3 and the blue ray features would work with my Maxent MX-42VM10 Plasma Screen TV? Thank you ...kev
Yes and no.  Yes you can connect the PS3 to the plasma using the component video inputs, games and videos will play fine.  However the native resolution of the TV is only 480P (852X480 pixels) which is much lower than the 1080P that the PS3 is capable of.  If you want a tv that can get the best possible image from the PS3 you would need a TV with full 1080P resolution and HDMI ports for digital input. Hope this helps!
Nov 29, 2008 | Maxent MX-42VM 42 in. Plasma HDTV
Connecting Gateway HDMI TV to Playstaion 3
If your PS3 has HDMI capability and the monitor has HDMI capability, it should work as long as the monitor can match to the specs of the PS3.
I am not sure, but I think the PS3 required the capability of 1080p from the TV set. Make sure that your TV is able to see 1080p.
For HDTV, the standard A/V cable set is of no use. That is why your monitor probably does not support the standard A/V format.
Jerry G.
May 18, 2008 | Gateway FPD2275W LCD Monitor
PS3
Avr 745 HDMI only output 1080i not 1080p. Your PS3 is capable of 1080p. You have to adjust your PS3 to 1080i then your screen will work. I hope Harman will come up with the upgrade for HDMI that can output 1080p otherwise you have to suffer or stuck with 1080i. Hope this will solve your problems.
Oct 14, 2007 | Harman Multimedia AVR 745 Receiver
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
224 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
