Question about SanDisk Sansa Clip MP3 Player
Message "USB device not recognized", cannot connect or add songs
I have used 2 other cables and tried on several computers, all get the same message. It starts to refresh, then turns on, then refreshes in a constant cycle. It does charge, but I am stuck forever with the same songs. My wife's now does the exact thing.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
Ipad disabled how do I connect it
Use the charger cord to connect the iPad to a computer with iTunes on it.
Dec 04, 2014 | Apple iPod touch
Printer not being recognized by computer
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
I installed the PC Suite for my LG BL40, but it won't connect via USB and my computer doesn't have a bluetooth device. |Ive tried everything suggested and when I connect choosing Music Sync, it connects bu...
First, syncing is the transfer of data between computer software's that are designed to acquire and share with another entity. The sync function usually is embedded in the computer program. Once the computer recognizes compatible software that has several capabilities including transferring data, a USB connection capacity should be achievable. Usually devices that are designed for data transferability should be capable of acquiring a USB connection either as physical cables or wireless Bluetooth technology. The power to sync is contained in the software program. Once software that has sync capabilities is installed on the computer, any USB cable that is attached to an empty port would display a user message asking for further procedures. For example, USB connections on the computer that has media software's would display device recognizes link requiring data transfer. The solution lies in the software that is relied on for sync capabilities. Acquire Windows Media player, Real One player, or ITunes player as downloadable onto the computer to achieve compatibility.
Important Notes
USB ports are available on all computers as versatile connection links to devices that would require communications. The computers original systems are expected to recognize USB cable connection as manufacturers default. Usually, the computer is likely capable of upgrading several software programs that would least communicate with the USB. For example, the program suit installed has compatibility requirements to perform on the computer as an entity. Also, the program suit requires compatibility with USB connection for another device that would be connected to the computer. Attempt to install media transfer programs that are designed with sync features.
Jan 26, 2011 | Computers & Internet
Cannot add new music or access previously loaded music
I know you hate to do this,..but reset your sanDisk, first,..if you've done this and it still doesn't allow you to add, will need to make a change in your settings....go to USB, then make sure you have selected "Auto Detect".
Jul 07, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
SwiMP3 was not safely removed and now it is not recognized
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Jun 12, 2009 | Finis Swi MP3 Player
Computer doesn't recognize MP3 player -
Check My Computer. If the PC recognises the Sansa player then simply add the songs by dragging the files into the player's icon on My Computer. Sometimes this kick starts the built in software included on the mp3 player.
Apr 01, 2009 | SanDisk Sansa Clip MP3 Player
Sg4 problem
This may sound crazy but I had the cable connected incorrectly (I was getting a message that my Sky Caddie SG4 was unrecognized). When connected the cable correctly (to the back of the SG4) the cable wire should be pointing down.
Thats all it took to fix this issue for me.
Jul 03, 2008 | SkyGolf SkyCaddie SG4 GPS Receiver
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
Dec 26, 2007 | Creative Labs Zen V MP3 Player
Hp laserjet 1020 ( usb device not recognized )!?
I'm not sure, but I think I understand that you're connecting using a USB hub? If so, try connecting it directly to a USB port. Many times an unpowered USB hub does not supply enough power to run a laser printer. Unhook the printer. Go to Printers and Faxes - delete the printer. Hook up directly to a USB port. Let the computer re-install the printer. Let me know Ed
May 05, 2007 | HP LaserJet 1020 Printer
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
