Question about Kitchen Ranges
Kenmore stove surface unit light stays on
Light stays on when all control knobs are off I have the same problem the red light on my kenmore model #911.91188890 is staying on when all my surface knobs are off and all burners are off. Can you tell me what the problem is and how to fix it.
  • 117 Answers
When the indicator light does not shut off when the burners are turned to the off position, this indicates one of the infinites switches are shorted. If comfortable with electricity, unplug the unit and remove the rear cover exposing the infinite (burner) switches. Using a bright flashlight, shine directly on one of the switches and you will see the following markings. L1 - L2 - H1 - H2, and then the Letter P. This letter P is for the pilot light. Since there is no way of determining which switch is shorted, remove the wire from the letter P on one switch. Isolate the wire removed so it is not touching anything. Place a piece of black electrical tape around the end to be safe. Next, plug it back in. If the light is still lit, move on to the next one until you have found the switch that once the wire is removed, the light does not light anymore. Replace that infinite/burner switcha nd all is well. If I can help further, I am here.
Waiting to hear from you,
Eric Campion
Posted on Feb 13, 2009
  • cahillss Nov 10, 2010
    yhank you
How to replace switch for 8" element in Kenmore electric stove model c880 6373190
Stove Surface Element Control Switch Replacement ...
? 3:09
Nov 14, 2013 - Uploaded by
This video provides step-by-step repair instructions for replacingthe surface element control switch on a ..
Oct 30, 2015 | Kenmore Kitchen Ranges
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
Nov 12, 2010 - Uploaded by
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ... > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Can I replace a kenmore stove burner with a GE burner
It depends on the Kenmore Model. Kenmore is the brand name for models sold by Sears, but they are not all manufacturered by the same company. They are made by Frigidaire, GE, Whirlpool, Amana, Samsung, LG... just to name a few. If you can post a model number of your Kenmore, I can give you the options for which elements will work for your machine.
Jul 11, 2013 | Hotpoint WB17X5113 Stove Surface Burner...
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
We have a Kenmore model #790.96011407 range with smooth top. It was working fine until recently one, then the other, front burner started operating on their own. They will not turn off when you turn the...
If this is happening on more than one burner the command module may be bad, small cicuit board inside control panel. With power disconnected easy replacement. check wiring to each burner control 1st by removing control panel cover. Be careful to remove small screws on either side of panel between panel & burner.
Jun 27, 2009 | Kenmore 96012 / 96014 / 96019 Electric...
Hot surface light indicator stays lit
The hot surface light is controlled by a part attached to the element called a limiter. For your model, the limiter is not available as a seperate item. The element/limiter assembly has to be replaced as a single unit. The top assembly, elements and limiters are all fragile parts.
If you are making this repair yourself, make sure the range is disconnected from it's power source prior to service.
Apr 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
YOU HAVE A SURFACE UNIT SWITCH GOING BAD take off the back and look at the switches if you have a volt ohm meter you can check for power to the light if you dont have a meter you can unplug the stove and pull each wire 1 at a time and see which one is sending power when plugged back in once you find the one replace it and problem solved
Jan 09, 2009 | Equipex PZ-330 Electric Single Oven
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
4,805 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
