Question about Toro Super Blower Vac
My Toro Super Blower works fine & then I notice smoke at the cord
The motor and everything else appears fine and I've also checked out by interchanging the extension cords. Something is causing it to suddenly start smoking enough to singe the connection area. By that, I mean where the Toro cord connects to the ext. cord. In this case - smokin' hot is Not a good thing. Could it possibly be a short in the Toro pwr. cord or should I be looking more for an engine problem?
Thanks!
Chris
  • 4 Answers
Sounds like your blower is drawing to many amp`s for the cords your using for this
Posted on Feb 13, 2009
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Blower does not turn on
Apr 03, 2014 | Toro Garden
Snow blower shorted out
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
I have a Toro Super Blower Model 51591, and need a replacement power cord. None of the online catalogs show this as being for sale. Can you recommend an alternate source?
You probably won't find one (at least I haven't). But if your cord was damaged in the same way as mine (at the base, where it goes into the unit), I will be happy to share with you DIY fix that worked for me. Email to radist2000@yahoo.com.
Jul 16, 2009 | Toro "Toro" Super Blower/Vac
Toro Super Blower Vac Logo
319 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
