Question about Apple iBook G4 Mac Notebook
Image color resultion is completely off i cant view images proper
Any images that appear are viewed in what seems like negative exposure
  • 1 more comment
  • pbeck May 11, 2010
    have you tried: Ctrl opt cmd 8
  • Anonymous May 11, 2010
    Is your whole screen gone to white on black? There is an option to do that in the Universal Access Preference Pane; perhaps that needs to be unchecked.
  • JG1977
    JG1977 May 11, 2010
    have you tried system preferences/displays/
    then check to see the surrent display setting?
    Scholar:
  • 53 Answers
Hey,  First go ahead and restart the computer to see if the problem persist.  Then if it does.... Have you done any changes to the Dispay settings?  If you have the hardware utilities disk, insert that in the cd and restart. It will run a system check on all video components in the process.  This will help to determine if its a display defect or a software issue.
Hope this helps!
enov8
Posted on Mar 06, 2009
I took some photos that appeared in negative. please show me how i can repair those photos. thanks
Many image viewing/editing programs will let you change between negative and positive images, but the simplest thing in Microsoft windows is to just use the built in Paint program. Open the image and select "Invert Colors" from the "Image" menu. You may want to save it out with a different name so you don't erase the original.
Feb 27, 2011 | Samsung S760 Digital Camera
On my Nikon D70s, when I take a picture and see the image previewed briefly on the back LCD, the highlights flash negative image tones(black) in about 1/2 second intervals. This same effect is also present...
There is nothing wrong with your camera. What you are seeing are the blown-out highlights. Those are the portions of your image that have been overexposed so completely that they have lost all detail and will show up as pure white. In most cases the proper fix is to reduce exposure to bring back the detail.
If you simply don't want to see the "blinkies", press up/down on the multiselector repeatedly to cycle through the different views of your images.
May 16, 2010 | Nikon D70s Digital Camera
Graph screen showing over photo image when using view finder
You're seeing the histogram, which shows valuable information about your picture's exposure. While viewing, press up/down to cycle through the different views of the picture.
Apr 03, 2010 | Nikon D60 Digital Camera
My dsr pd170 lcd view screen is viewing in negative imaging. it seems to be filming fine, but the image quality slowly degrades while filming. Since we work at a camp and film things like talent shows...
dear
first tell me when u close the lcd pannel , then is the view finder working fine , if not then
view finder cable is broken . u cant fix it your self as u need to open the camcorder .you must not be having the proper tools for that.
and regarding the lcd part , if the display is fine for a while ..and then
while using it it goes fade , shows grey colour or lines in it . then its lcd problem ...ur lcd need to be replaced .
Jul 25, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Pictures appear to be darker than original in print outs.
You can make several adjustments to improve your images such as lightening dark areas, changing the exposure, sharpening blurred edges, and changing the brightness and contrast.
  • Exposure adjusts the overall intensity of light in an image.
  • Adaptive Lighting improves only the dark areas in an image without affecting the bright areas.
  • Brightness adjusts the amount of light in colors ranging from light to dark.
  • Contrast adjusts the difference in brightness between light and dark areas of an image.
  • Sharpness helps define edges and the smoothness of texture in an image. Use this tool to make a blurred image appear more focused.
Adjusting the image Follow the steps below to make adjustments:
  1. Click the View tab and select the image you want to edit by either clicking the image, or by clicking the small box at the bottom left corner of the image. Figure 1: Select the image c00603524.gif
  2. Click the Edit tab and then click the Advanced tab.
  3. On the Advanced tools tab, click Adjust Image .
  4. Select an adjustment from the list on the left. Figure 2: Adjusting the brightness c00603525.gif
    • The Exposure adjustment is automatically applied when the Adjust Image tool opens. Eight variations of the image are displayed on the left. The current image is displayed in the center. Each image represents a different level of adjustment. When you move the pointer over any of the images on the left, a large version of the image is displayed. Use Preferences to turn this large image preview on or off and to set the timing for the display.
    • If you want to use a different adjustment tool, select Adaptive Lighting , Brightness , Contrast , or Sharpness from the list.
  5. Select one of the images on the left.
  6. Do one of the following:
    • Click Accept to accept all changes and exit from the Color Toolkit.
    • Click Cancel to discard all changes and exit from the Color Toolkit.
  7. If you have finished modifying the image, do one of the following to save your changes:
    • Click Save to overwrite the original image.
    • Click Save As to save the modified image with a different name.
Aug 25, 2008 | HP Photosmart D7160 InkJet Printer
No image. The menue (etc.)
On the display button...See catalog properly....
Jul 09, 2008 | Canon Cameras
Problems taking TIFF photos
I have seen similar problem on one of the SD card. Tried another SD card and it works fine with TIFF. I think it is related the the SD card compatibility.
Jun 22, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Sony Digital Still Camera - DSC T33 - Image Stored and Playback is in Negative
This is one for the Sony Tech support Have you E-mailed them. The negative mode you mentioned would seem to indicate an exposure problem.
May 14, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
Blue and red squares over my image
A histogram is a graphic representation of the distribution of brightness values in an image. The C-5500 has two histograms. One displays a real-time graph on the LCD screen as you compose your images and during the Quick View of images after they are shot. The DIRECT histogram displays potentially over and under-exposed areas in the image with a grid of squares—red for over-exposure and blue for under-exposure. You can set the histogram to OFF to prevent the histogram from appearing.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Apple iBook G4 Mac Notebook Logo
62 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
