Question about Maxtor Personal Storage 3200 (M1227310) Hard Drive
500Gig HD Power Supply has Died - What can i do?
The power supply to my WD 500g external hard drive lights up then goes out again with nothing happening.
  • Anonymous Mar 10, 2009
    I have the same problem! Just happened, I plug it to the socket, LED lights up and goes off... and nothing happen. I am not sure if this is an standard power supply :( I will go to the store and complain!
  • 36 Answers
The power supply is probably dead. if its under warranty return it for replacement. if not under warranty have a local technician check the power supply.
Posted on Feb 14, 2009
My 'Elements' WD 500G external hard drive is no longer powering up - it has an external separate power supply (it isn't one that powers via USB only). The power supply 'box' is flashing a green light. Do I...
If it is a matter of just the power supply failing, you can get a replacement. It is possible to remove the HD and place it in a new case with a new power supply, as well. However, if you suddenly smell something burning after that, you are on the trail to adventure. That might be a burnt out diode, easy enough for a PC repair shop to replace. Or, it might be something more serious and you would need an expensive data recover shop to get back your loss. You could call Western Digital customer service and see what they have to offer in terms of a power supply or make use of the following link:
Amazon com 12V AC power adapter for western digital elements WD6400EB035...
Oct 21, 2017 | Western Digital Elements powered by WD 320...
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
Power loss in external harddrive
Hi mjcole,
Couple things. What model WD drive do you have? Plugging the laptop adapter into the drive chassis may have fried the chassis. You can buy a new chassis and put your drive into it, or you can buy a new power supply in case the one you have has gone bad and you did not realize it. Not likely though.
The power requirements are very specific and the laptop power supply may have been to much for the WD drive.
Feb 12, 2010 | Western Digital Elements powered by WD 320...
I lost the power supply for my WD2500 external HD.
My Book Essentials
12 Volts
3.0 Amps
36 Watts
Sometimes WD will even send you a replacement free of charge, if you give them a call.
Jan 24, 2010 | Western Digital 250GB MyBook External USB...
My WD external HD "element" will not turn on
When you say it won't turn on, do you mean, there is no spin-up and not LED. If this is the case disconnect it from the power source and then reconnect it. If the LED flashes once or doesn't appear at all, the power supply is faulty and you will need a replacement. If you call WD, they will send you a replacement power supply free of charge.
Jan 20, 2010 | Western Digital Elements powered by WD 320...
Hard drive will not power ON
I have had my own experience with Western Digital and their policy is to not sell or provide parts in order to replace damaged parts in an otherwise functional device.
Your options would be to send it in to WD for a repair and strictly a repair. They may replace the power supply.
The other option is to buy a used/off-market case or power supply which matches your drive's supply.
I had a harddrive burn a hole through one of the interface chips on the bottom of the HD and was told there was no way I could get it repaired or recover the data as it was. However, I found an exact match for model and type of the drive and a near enough year to the one I had and exchanged the interface boards on the drive, and I'm using the drive today as my main boot disk.
All you need to do is replace the power supply. Try Ebay for your external drive model number, there may be cases with no drives which you could buy that have functioning power supplies, or power supplies alone.
If all else fails, you can do what I did - buy another, matching product, exchange the broken part from the new one you get with the old one, recover data, and swap the power supply back again, then send the old drive to WD for replacement. You can attempt to resell the RMA'd (returned to WD drive) on amazon/ebay and use the new one, or keep the new power supply in the old device and use it, and sell the drive out of the case, or keep the drive and use it. I expect the drive inside the external case should work as a normal drive.
Dec 16, 2008 | Western Digital 500GB My Book Pro-External...
POwer supply failure
Hi John,
Had the same problem with a WD Elements 320 GB drive, and found a WD customer service number. They are sending me a FREE replacement. I have put the details on a message somewhere on this site, but can't direct you to it.
The number from Australia is : 1800 429 861 ( routed to Singapore )
Email Address : Western Digital Customer Service .
Send them details of your mailing address, drive model and serial number, and a description of your power supply. ( my power supply had a model number moulded on the back )
Hope this helps
Dec 15, 2008 | Western Digital Elements powered by WD 320...
Help! the green light flashes then nothing happens
The exact same thing just happened to me (WD elements 500 gig) and it's only about 10 months old. I called the customer help line (on the official website) and after they asked me what the serial number of my HD was they were going to send me a new power supply. Simple as that. They said they'd be able to send it out early next week. I'm hoping that the HD didn't get fried and it's just the power supply but what you've described is EXACTLY what is happening to mine.
Oct 31, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Maxtor Personal Storage 3200 (M1227310) Hard Drive Logo
164 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
