Question about Samsung R65 Notebook
How to perform of Samsung Laptop base system device error
  • DEKR
    DEKR May 11, 2010
    please explain
    i need more info
  • 21 Answers
Check to see if you have a card reader or a usb plugged into the laptop. That is what usually gives you the errors.
Posted on Feb 13, 2009
My Samsung rv515 0a5ca wont boot, but the power light Still on
Hopefully if you have all your files backed up, perform a System Recovery with your operating system, or better yet, You may restart your laptop and tapping F8 at the same time, perform a system recovery thru the Safe Mode.It may be a corrupted software with the "boot.vis"
file.??This is the best i can do without seeing your laptop.
Aug 23, 2014 | Samsung RV515 Laptop
What is the base system device on my Dell laptop?
A base system device is any hardware device pre-installed on your laptop, such as a CD-rom drive, a USB port, an Ethernet port, video card, etc. These devices all require pre-installed drivers that were supplied by Dell with the factory setup. The most common problem is to have one of these driver files corrupted or deleted by accident. To solve a base system device driver problem, you have to go into Windows Device Manager (Look in Control Panel), and look for devices listed with yellow question marks or other indications that they have a missing driver. You either then go to the Dell support site for your laptop model, or the driver disk you may have gotten with your laptop, and reinstall the needed driver.
Jul 22, 2014 | Dell Inspiron Computers & Internet
Internal hdd hard error
Using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
Nov 19, 2013 | Dell Latitude D610 Laptop Computer -...
I received an error code 0X490 in the system files integrity check and repair. What is this and how do I fix it?
Copy and paste the following link into your internet browser for details on this error:
Feb 18, 2011 | Dell Inspiron 1525 Laptop
Had blue screen on laptop took advice and put laptop hard drive in Samsung drive enclosure My desktop can see the drive but I just get the message 'error performing inpage operation' Does this mean my...
Click RUN and cmd then you'll be in command window - then type chkdsk [drive:] /F (such as - chkdsk e: /F) which should perform a repair
hope this helps
Dec 04, 2010 | Samsung HM060HI Hard Drive
Base system device and network controller driver error in device manager at win XP
"Base System Device" is your card reader, I had the same problem. If you dont use it jst disable the device, otherwise the drivers should be on your alienware Master CD, if not get a tech support guy to send 'em to you.
May 25, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
The last problem to conquer
base system device could be the audio on the motherboard or the audiocard itself. go to the page that has system devices and find your audio and supported devices and see if the latest driver is available. when you repaired the connector, I take it you had to pretty much remove everything to get to the board connector. could it be you didn't reconnect a connector? those thin film flat cable connectors can be a pain.
Mar 10, 2008 | Compaq Presario R3000 Notebook
Acer 5570z laptop ql2200.sys error
Clean the recovery CD if you are using one.
If the recovery runs from the hard drive you may have a failing hard drive.
You can download an image of a CD (an ISO file) from
If you dont have software or are unsure how to burn an ISO image get this:
Dec 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Samsung R65 Notebook Logo
492 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
