Question about Phase Linear UPA424CS Car Audio Amplifier
Whining noise from amp.
Is it possible that the noise is coming from the positive line from the bat. When I turn the car key to the first positon I hear the radio and it is claer as a bell. Then I turn the key to the second position and the noise starts. Then I start the car and it gets alittle worse. Its coming from the alternator i cna hear that. I have tried 2 spots for grounding. I have changed my grounds my wires and everything else. My RCA plugs are running from the radio straight down the dash under the rug to the amp. There are some vents but really no wires. The amp is a Phase linear upa424. The car is a mountaneer. The speakers I have running from the harness to the amp. Could that be the problem? I have been tring to fix this for a week now on and off. I am not much to ask for help but here I am. Is it possible the noise is coming from the positive from the battery? I have it connected directly to the terminal.
  • 2 more comments
  • danieldalbey Feb 13, 2009
    I am going to try the open rca first then the ground. I have had the head unit connected with out the amp and I had no noise what so ever. I am thinking that maybe there was some noise that I just couldnt hear. Putting the amp on has made the noise lound enought to hear. This site is awesome. Thanks. I will let you know what i find out.
    OK I tried the rca cables. I had readings of 0.3 to 0.4 between the head unt and the rca cables. I tried the ground to the battery and no change. Next will be the noise filter. I am going to run that and get back to you.
  • thunderboy8 May 11, 2010
    try running a ground to the battery. if no good, then try put a 'noise filter' on the power supply to the amp/head unit.
  • Perry Babin May 11, 2010
    You may have open shields on the RCA output of the head unit. The procedure to check them can be found on the following page.
    Testing RCA Shield Ground
    Let me know if you have any other questions.
  • 34 Answers
Hear are couple things to try   try running your power and  (ground) both directly from your battery   to the amp and  to the receiver .. if this doesn't help try purchasing a noise suppressor  and wire your receiver threw this  it should solve your problem
Posted on Feb 17, 2009
1999 Pontiac Sunfire 5 speed won't start. Replaced spark plugs and checked ignition coil (fine). Sounds like it wants to turn over but makes a "whining" noise. Please assist. Thank you!
Is the engine turning over with the key in the start position? If the engine is not spinning over and you hear a whining noise, the starter is not engaging the flywheel. If the engine is turning over with the starter engaged, the engine has most likely jumped time that creates low or no compression which results in the whining noise.
Mar 03, 2015 | Pontiac Cars & Trucks
Whining noise
Change the transaxle fluid & add a bottle of Red Lubgard
Also do the Power Steering Fluid & add Lubegard to that
Still there-- I would guess the trans is failing
Too high a speed for a wheel hub bearing,but possible
Mar 20, 2014 | 2007 Ford Edge SEL Plus
1996 plymouth neon started and then died and now won't start
Go to your car and turn the key to the on position. You should hear a whine for about 2-4 seconds that is the fuel pump priming the fuel line. This sound will come from inside your gas tank, but you should hear it as you sit in the car or have somebody look under the car near the gas tank to see if you hear it. It will whine for 2-4 seconds and if you shut the key off and turn it back on, you should hear the whine again. If you don't hear anything, then it sounds like your fuel pump is out. If you do hear something then it might be ice in the gas filter or in the line somewhere.
Dec 02, 2013 | Plymouth Neon Cars & Trucks
Problem fuel pump not working 2001 B 3500 Van
check fuses, & relay , relay may have fuse also. when you turn key on, the fuel pump will whine for a couple seconds, have an assistant turn key to on position, donot start, while you listen for whining noise @ tank. if you hear the noise, pump works, if nosound, replace pump. but make sure its not jusj a fuse, or relay first.
Feb 02, 2013 | Dodge Ram 3500 Cars & Trucks
Whining noise when changing gear
U might need some grease down there in the box.
Aug 28, 2017 | Cars & Trucks
Key start turns and makes a whining "I sort of want to start" noise but does not engage the engine. Previously the key start was sort of touchy and the key had to in just the right position to engage the...
If it is whining, the starter motor is turning. You possibly may have a broken starter drive. This is the little gear on the starter shaft. It's not too expensive and relatively easy to replace.
Apr 19, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have defrost and vent function,but no heat to the floor.
sounds like your control for this function is bad also check the electronic bypass door switch electrical connection for looseness & possibly broken arms. With control on hot,the fan on low,turn the key on for @ 20 sec. With the key on turn the heat control all the way to cold now turn the key off instantly & put your ear to the floor next 2 the heat vent & u should hear the door of the vent make a whining noise hense changing from open 2 close 4 another 20 sec. GOOD LUCK!! BEEN THERE & DONE THAT!!!!
Jan 05, 2010 | 1999 GMC Sonoma
2004 nisan won't start. how to check the fuel pump & filter
let the car sit for an hour and then turn key to on position then you should hear the feul pump whine to prime the lines. dont try to start it just go as far as the on position.
Jul 11, 2009 | 2004 Nissan Sentra
Phase Linear UPA424CS Car Audio Amplifier Logo
481 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
