Question about HP Photosmart C5280 Printer
Calibrating printer to print Sure Thing CD labels
This is my first time calibrating a printer. I printed the calibration sheet and folded it in half, both horizontally and vertically. I am ready to enter the values but don't understand what to look for. What does, "Enter value where the crease intersects the axes mean"? The creases are down the middle of the paper. Please Help.
itdude4321
  • 13 Answers
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Posted on Feb 02, 2008
Postalsusie
  • 40 Answers
SOURCE: need 2 calibrate my hp 1210 printer
Hi *s*
(bottom left corner windows START)
got to;
start/settings/printers/ and click
right click your printer and select printing preferences
click on the tab that says SERVICES
then click on the services icon button (picture)
you will see three choices;
align,
clean
print a test page.
Aligning is what you want.(calibration is just a different word)
You can also remove the ink cartridges as you usually do and then put them back in, this triggers and automatic printed page and then walks you through scanning and the alignment.*s*
if by chance you still have blurry printing and know your machine should be ok, try cleaning.( same procedure, different last choice- you clean the heads)
You can also check to see if the proper paper is selected. For instance, if you are trying to print heavy greeting card paper it must be set to that or it will not print properly. *s*
If you have thrown up your hands and tried all this, and nothing works. Go through your printer preferences and select SET DEFAULT SETTINGS buttons.
It will knock everything back to the way it left the factory *S*
Thank you and good luck. Please remember to give my answer a rating *S*
Posted on Oct 28, 2008
  • 990 Answers
SOURCE: HP Laserjet 1300 paper creasing on printing
change toner cartridge will be OK!
Posted on Dec 16, 2008
  • 2976 Answers
SOURCE: calibrating 5100 kodak all in one easy share printer
Go to the printer maintenance program and select "Calibrate printer".
Posted on Jan 31, 2009
SOURCE: Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Posted on Apr 15, 2009
Zebra S400 does not keep the calibration settings. After calibrating or restoring factory settings (like described in the manual) first label prints OK (using BarTender software) then it's off again. Same...
After you calibrate the printer. Press feed a few times. If it feeds a single label each time, then the calibration was successful.Power off and on while holding the cancel button. (config printout). Keep config for reference. Send label print from computer. If it does not work, then check that the printer driver matches the config printout. The computer printer driver will change and overide the settings in the printer
Apr 29, 2011 | Zebra Stripe S400 Label Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Aug 06, 2009 | Zebra S4M Thermal Label Printer
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
Jan 28, 2008 | Zebra Stripe S600 Thermal Label Printer
HP Photosmart C5280 Printer Logo
289 people viewed this question
Ben Johnson
