Question about HP Pavilion dv6000z Notebook
Remove the battery on my laptop-
I am trying to figure out how to remove the battery on my laptop- an hp pavillion dv1000
    Sergeant:
  • 183 Answers
There will be a battery latch to push while you yank out the battery. Sometimes , there is a battery lock, which is another switch near the battery latch. You may need to use a lot of force.
See the pictuer:remove the battery on my laptop- - c24e0e3.jpg
Rate all answers.
Good Luck
Posted on Feb 13, 2009
  • 565 Answers
There is a flip u move then i pops up
  • Teet Bergmann Feb 13, 2009
    if helped rate fixya - its under the laptop near to battery
My hp pavillion dv1000 laptop fan doesnt work..
Have to try to update the BIOS on your machine? usually that's what HP support do, you can download the BIOS driver to HP website. If happens that you already updated the BIOS and still the fan is not working, it means that the Hardware is faulty.
Feb 27, 2011 | HP Pavilion dv1000 Notebook
I am unable to get the old battery out of the remote for hp pavillion dv 1000
Usually there are a few small screws holding the cover. The battery is located under the computer. Remove the screws and slide the cover off. You should be able to see the battery now. Just pop it out with a finger or two.
Feb 23, 2011 | HP Pavilion dv1000 Notebook
I have an hp pavillion dv1000 it works fine but the screen is very faint i can barely make out the icons... i tried pushing fn f7 which is supposed to make it brighter and nothing happened... any...
the backlight may be going or has gone out, is it plugged in or running on batteries? when plugged in it should be bright with a battery is usually dies down so as not to use alot of energy.
If that does not help, try function key and making it darker, I know that sounds weird but sometimes it gets stuck in a weird loop, My dell laptop does it all the time.
Sep 10, 2010 | HP Pavilion dv1000 Notebook
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
Letters keep typing even without keyboard
I'd try wiping and reinstalling the operating system or booting from a linux live-cd first to see if it's a windows issue or hardware issue. In the end though, yes I believe the motherboard is probably faulty.
Jan 22, 2010 | HP Pavilion dv1000 Notebook
I bought a new ac charger for my hp pavillion dv1000 it will not power on
Check and make sure the Voltage on the AC adapter is the exact same as your previous one. Just because the connector fits in the port, doesn't mean it's the right one. Look in your manual to figure out if your AC adapter voltage is correct. If it is, it's possible that you have a dead battery, it happens when surges happen during power outages. If it's so, look on the HP website for a new replacement battery. It should allow you to type in your pavillion model number.
Jan 08, 2010 | HP Pavilion dv1000 Notebook
Hp pavillion dv1000 notebook cant hear or see fan running
First thing you should try is blowing out the vents / fan with some compressed air.
Make sure you remove the battery before doing this, I also recommend letting the computer sit for 5 minutes before you power it back up again.
If that doesn't solve your problem you might need to take the laptop apart and reapply thermal paste to the cpu and heatsink.
Let us know what happens.
Best of luck!
Mar 04, 2009 | HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
Hp laptop issue
can u explain....only icons are not showing.??? what abt the start menu and all other applications.? does it work fine..?
Dec 22, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv6000z Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
