Question about Acer Aspire 5315 Notebook
Sudden shut down
Aspire5315.bios updated to latest .winxp os
  • acharyappm Feb 19, 2009
    the bios is now updated but core temp is more than 80c though no shut down now is it ok
  • jim beckwith May 11, 2010
    check for a virus
    Genius:
  • Acer Master
  • 1,102 Answers
Restart in bios setup
then set to default
press f10 to save and exit
then do a disk defrag
let me know if you still have problems then i can provide another solution
Posted on Feb 13, 2009
Hi I have Dell Vostro 1520 Laptop ( Intel Core 2 Duo)/WinXP, 4Gb RAM/ Intel VGA graphics adapter . Inwhich Blue screen is coming having error message 0x000000EA. i have Format Hard Disk,reinstall Os,...
Video error. If not already done, update the graphics driver.
Try booting in VGA mode, if no joy then try booting to safe mode and uninstalling the graphics driver leaving the windows "vanilla" driver.
I
Jan 10, 2011 | Computers & Internet
Where to download drivers to update the BIOS for my IBM desk-top
Ha! Old OS, old URL; possibly just an old desktop not up to the task of running WinXP.
It's a new BIOS you'd flash your system with, and probably a push between your motherboard's BIOS having an update (you'd go to the mobo's maker's site, e.g. that of ASUS, Gigabyte, Intel, etc.; read the screen-print on the board; to get the update) and telling WinXP to install anyhow using a handy force-install option.
May 02, 2010 | Computers & Internet
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz (2 CPUs)... can i install 64bit OS
It appears from the Intel support site that the "latest" supported 64bit OS that includes a OS specific BIOS driver update is WinXP Professional x64.
Dec 26, 2009 | Intel D845GVSR Motherboard
PC shuts down after logging in to WinXP pro Athlon uP
reinstall the window xp
open my computer from the start manue
go to view and open folder options
show the hidden files and also deselect the protecting window files below it
and apply
then click on the folder on the top in the my computer
and remove all the suspected hidden files from all the drives and restart your system
Dec 21, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Can we/should we update our bios?
I would not update the BIOS if you aren't haveing problems. If you use WinXP you should have no problems updating the Hard Drive to the 500GB, If you format the disk using the NTFS File system when you install windows, and it only recognizes 137GB of the 500GB, then update, but you shouldn't have any problems. thanks for any ratings
Mar 30, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Ntldr is missing, press ctrl,alt and del to restart
the ntldr.sys file is used to boot your winxp, this should have got corrupted, or your boot sector in the harddisk should have got corrupted.
what file system was used on your harddisk ( Fat32 or NTFS)
if it is Fat32 then you can try this. boot your system with win98 boot cd or floppy. after booting insert your windows xp cd in the cd drive copy the file ntldr.sys from the i386 folder to the os root dir(usually the c:) you will receive a overwrite message. do the over writing. thats all.
now restart your system normally (harddisk). it should be fine.
if the file system is NTFS, i am sorry to say, if you dont know the admin pass, you will have to repair the installation with the winxp cd,
for this boot your system with the winxp cd, on the first screen, press enter( for a fresh installation), then press F8, now you will be notified that there is already a window installation, on this screen press 'R' to repair the installation. follow the online screen.
Actually this is a nothing but just a reinstall of the OS. you may have to reinstall most of the os updates. and a few softwares also.
Hope this helps you.
Jan 09, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Averatec 3200 Blank Screen
your lap top overheated, get a new motherboard.
Dec 23, 2007 | Computers & Internet
Computer shut down during adobe photoshop project
there is a problem with your OS system file or with your adobe software.
you can try following options....
1. Go to Microsoft update and check whether your OS requires any updates or not.
2. Try to Uninstall completely Adobe Photoshop and reinstall again.
3. Use Easy cleaner OR System Mechanic OR WinXP Manager Software to keep your PC clean from junk files and registry also...
Nov 30, 2007 | Computers & Internet
Firewire PCI pcb won't work
just do this: check out the bios wether the option for pci slot is (yes) or (no).if it is no change it to yes. this may help ur problem
Sep 27, 2007 | ASUS (P4BP-MX) Motherboard
Acer Aspire 5315 Notebook Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
