Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
The metal drip tube that is situated from the top part of the
Stove and down to a drip jar is plugged with bacon grease. How can I get this cleaned out?
  • 360 Answers
If you remove the tube, it can be gently heated with a torch and the grease allowed to run out, after which, pass large amounts of hot hot water through the tube. to clean without removing, I find a speedometer cable works best to get a path through the pipe, then again, large amounts of hot hot water to flush out/clean the pipe
Posted on Feb 13, 2009
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
True back bar freezing up
Most models have a metal drip collector below the evaporator that has a drain hole in it where the defrosted water goes into before it goes down to the drip trap and then out the drain hose. If the area around the drain hole has cracks, or was punctured during servicing, the drain water can get underneath the tray and run out beside and around the drip tray and never gets into the drain tube and freeze in that location. A careful inspection of this area will reveal any issues.
Aug 15, 2014 | Refrigerators
Grease dripping from bottom of microwave
sometimes when a microwave is mounted above a range some people dont always consider that you have to take into consideration that you have to go by the heat rating guidelines because it will melt the white lithium grease off the gearing and it can possibly melt some of the protective coating from the circuit boards so check if it is rated to be placed above a range and go from there
Jan 31, 2014 | Microwave Ovens
I've got grease dripping down from the top left inside corner of my otr microwave. I've cleaned the grease filters. Is it a problem with the vent to the outside?
Without a long explanation as to why but they will get a build up. At this juncture i would be prudent to just clean it well. Because it will require you to remove the outer cover, you must disconnect it. Be careful when you do this, no metal objects. It has parts that store electric. Once you open it you will see the build-up. Do not open the metal box, it is the part that stores the electric.
Nov 10, 2013 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
I love stainless steel appliances and have a lot of them at home. But, it is trouble cleaning them. They look really bad if they are not kept clean regularly. How can I get rid of the stains and marks on...
get a 'oxygen' based cleaner soak overnight.
normal cleaner works based on surfacetant. oxygen cleaners works by dissolving the stains.
of course, you can use some elbow grease and polish them.
Oct 16, 2013 | Ronco 'Showtime' Rotisserie and BBQ...
95 villager has right front brake drag, replaced the brakes, rotor, hoses, calipers and installed a used abs modulator. orginally it was right front left rear issues, not it is only right front
This type of problem can occur if the wrong fluid has been used at some earlier stage,in which case all seals need to be replaced along with master cylinder overhaul.
Jun 19, 2011 | 1995 Mercury Villager
We do not seem to be getting as much heat from the stove this year as last year. The stove makes a loud clanking sound when it heats up and cools down. It is a regency wood stove Model R3/R9/RA3. There...
That stove has a metal baffle on top of an air tube that can warp with age. It might be changing shape as it heats up and making your sound. If this is the case it can block the path for the stove pipe and cause performance issues. The baffle plate and insulating blanket on top can be easily replaced.
Dec 07, 2010 | Stoves Heating & Cooling
Oil mystierously appears on bottom pan of oven, 465, when in use.
Larry,
Your stove has no parts that contain any type of oil or grease. It's possible that the prior owner accidently spilled some oil on the stove. I would continue to clean up the grease and hopefully it will all run down and after the clean up, it will disappear.
You are welcome to contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service for any questions or should you need appliance parts or accessories.
We hope this helps and we wish you a Happy New Year! Ella
Jan 03, 2010 | Kitchen Ranges
Bacon grease in my bunn coffee pot
Did you let the vinegar mix with the hot water in the tank for 2 hours? If this didn't fix the problem, please call 800-352-2866 with the model and date code and we will be happy to assist you with this problem.
Mar 29, 2009 | Bunn BCW Coffee Pot and Decanter Warmer
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
207 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De GO PATS
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
