Question about LG Studioworks 45 14" CRT Monitor
LG studioworks problem of display[Yellow color]
There is a problem of my monitor .It will display in yellow color,and there is a horizontal lines in the screen.The brightness will increased some times and at last nothing can see because of full brightness and horizontal lines.When i shake in the monitor then the brightness will normal but the color still in yellow.After some minutes all problem will occur again.Then i switch off the monitor, and after some times again switch on.So it will become the normal stage except the color .color becomes normal only in rare times.After some minutes repeat all problems.[some times when i shake the monitor all problems are solved and does not repeat the problem ]
  • 75 Answers
SOURCE: Very Bright Outdoor Photos with lines
The shutter is stuck. The electronic "noise" created by the solenoid trying to move the shutter blades causes the lines on your pictures. The bright outdoor pictures is due to the fact that the shutter is jammed open. You can try tapping the camera on the sides and bottom. This may jar the baldes loose. Failing that, you will have to find a shop that can obtain a replacement lens assembly for your camera.
Posted on Mar 31, 2007
techman
  • 3130 Answers
SOURCE: Sony warms up - picture slowly becomes dark
You are losing screen voltage or whats called the boast voltage most likely. This is probably being caused by a bad capacitor in the sweep power supply. You will need to get a service manual as well as use an ESR type capacitor meter to find the bad capacitor(s). Good Luck
Posted on Jun 05, 2007
Paeroa
  • 457 Answers
SOURCE: Problem LG XNOTE 229QA2
Please try and external monitor if the picture is OK then you are having LCD problems. I dont know for you but over in the States here: http://lcdrepair.net They maybe, are able to help you.
Posted on Sep 29, 2007
  • 65 Answers
SOURCE: Shake in steering wheel
Sounds like your brake rotors.You dont have to feel it in the pedal to get a shake in the wheel.
Posted on Nov 29, 2008
onyeredson
  • 404 Answers
Hi! Although my collegue has pointed out the possibility of Discs being warped or out of true? Have you thought of the wheel balancing? also have you tried changing the rear wheels to the front? you may have a well imbalanced wheel or a Tyre with a side wall defective i.e. an Egg? (Buldge). Another problem on big tyres is they don't seat correctly, check the beading is settled in fully.
Hope this helps!
Paul 'W'
Posted on Jan 04, 2009
Blue vertical bar Left side and yellow,red vertical bars are seen both side of screen cause images are not readable
Hello
If the monitor displays these vertical bars, after a service has been done to it, and if LOT has replaced, there is a mismatching problem with replaced LOT and the defelction yoke.
Dec 18, 2011 | LG Studioworks 700S 17" CRT Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
My monitor displaying yellow color in place of white
right click on the desktop ...properties...settings (should be the last in the right ) ..than advanced..and should display the monitor settings ..there get them one by one cause there are more then one setting and try to default them ...i fthe color is not getting to normal than reinstall the video card ..and after that if is still the same it means that something is broke in the monitor ...and need a proper fix..at the shop ...or ..if it is a cheap one ..just get another form a second hand dealer until you will afford a good one ..
May 09, 2010 | LG Studioworks 700S 17" CRT Monitor
this is because some dust might have gone inside your monitor so only you are getting this problem..... If you just remove it. It will work fine..
Feb 12, 2009 | LG Studioworks 45 14" CRT Monitor
CRT monitor becomes yellowish..
When any dust goes inside your monitor .......you will get these things.......... remove it , it will work fine
Jan 12, 2009 | LG Studioworks 45 14" CRT Monitor
How do i identify the wires of the lg 710s?
Vertical signal wire is yellow colour wire
Horizontal signal wire is White colour wire
Nov 22, 2008 | LG Studioworks 700S 17" CRT Monitor
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Screen displaying a thin white very bright horizontal line.... plz help
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Yellow Screen
there may be a problem with the monitor data cable. try shaking the cable only if it happens so then change the cable, if the cable is not broken then the transistors on the yoke may be damaged. then take it to the nearest repairman just vote for me so that i can help you better
Sep 06, 2007 | LG Studioworks 700S 17" CRT Monitor
LG Studioworks 45 14" CRT Monitor Logo
54 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
