Question about Motorola Mobility RAZR V3
DELAY BUTTONS when i turn on my motorola v3x, its fine but when i will read a txt message or txt somebody, i causes delay. ex. i press up and nothing will happen, and then i press down and it will go up, i press enter and it will go down. SORTA DELAY THING
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Try to format your phone...go to intial setup master reset and master clear...code is 0000 hope this will help you
Posted on Feb 13, 2009
My Westinghouse dishwasher is displaying HO2 what does it mean.?
H01-H24 Delay has been selected.so H02 means you have selected two hours delay.
Cancel delay setting if you don't need it.
Time Indicator and delay display:
The time indicator displays the program time and time
remaining for the program
In addition, you can delay the start of the program by
pressing the "+" and "-" buttons before the program is
commenced The delay function is indicated by the letter
"H" followed by the number of hours selected
If you want to change the delay time, you can reset it by
pressing START/PAUSE and then using the "+" and "-"
buttons to select the new delay time, then press START/
PAUSE to activate
Westinghouse WSF6606 User Manual Failure Codes And What To Do In Case Of...
Oct 25, 2017 | Westinghouse Dishwashers
GE Model WCVH6800 keeps pausing mid-cycle. I understand how to run the diagnostic but can't seem to get it to work. I unplug for 30 seconds and hit signal, delay, signal, delay but upon hitting the...
It stumped me first time. You have to unplug it, plug it in, then press signal-delay-signal-delay with in 30 seconds. You don't push any othere buttons first. Then it will lock the door, spin the drum, and go into troubleshooting mode.
Sep 24, 2011 | General Electric WCVH6800J Front Load...
How do I turn off the delay timer? When I set it up, the timer automatically sets it on a 3 hour delay. I have moved the up & down arrows but it won't set at 00:00 unless I unplug it. Then I set...
No offense intended but you need to step away and read the instruction manual step-by-step. One point I can make: The three hours you're seeing in the display when you first plug the unit in are simply telling you how long the default white bread mode is going to take to complete. It's merely a counter that counts down so at any time you glance over at the machine you'll know how much longer it's going to be before the bread is finished. The digital display has NOTHING to do with the delay timer until you start pressing delay timer arrows.
Hope this helps!
Jun 20, 2011 | Breadman TR777C Bread Maker
Dont know how to change txt alerts what section do i find alternative txt tones on motorola v3
1. press the middle button "-" at the top of the v3 keypad.
2 go to settings, and press on the button with a screwdriver and spanner
3. go to ring styles, press on the line below style.
4.Go to text msgs and press change to alter
Oct 23, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Frigidaire F/L Washer - Delay Start will not reset?
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
Nov 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 665 Ultra Wash FH141493
Hi daryano
I'm Harvey the Master Plumber
You want to know how to get the delay to work?
Most models work this way: Washing dishes the first time sets the favorites and the next time you start it the favs come on automatically provided you haven't changed the settings. So after the first use just hit delay and nothing else and when the dalay time is up it should work fine.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Aug 31, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Proline locking issues
The Proline manual (comes on a CD with the player) says:
6.3.7 Key lock
This function sets a time delay from when key lock function is started or the player is switched on, after which the player will automatically stop responding to the control buttons. Pressing any button will then display the message ‘Locked’. Key lock is useful, for example if you put the player in your pocket and don’t want any buttons to be pressed accidentally. The time delay is to let you start playing the music and so on. You can choose a delay of ten or thirty seconds, one, three or ten minutes, or you can disable key lock completely. •
Press and hold the V+ button for a couple of seconds to temporarily unlock the keys.
Mar 17, 2008 | Audio Players & Recorders
How do you change txting style?
Menu>Messages>Create Message>Options>Change Text Mode#>Secondary. thats how i change it on my one.
Nov 13, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Motorola cell
have you tried the faqs.from here http://motorola.com/consumer/v/index.jsp?vgnextoid=06e1dd9fc0e2b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00002&show=globalSupport&productID=48bfe2f9eb3d9010VgnVCM1000008206b00aRCRD
riz.
Nov 01, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
