Question about RCA P61310 TV
RCA P61310 Works on all inputs but ant a
My Father in Law has an RCA P61310. The Satellite will no longer work on it. You can switch inputs and watch movies or play video games, but the satellite won't work. When you plug into ant A it says weak signal, and when you plug it into ant B it says no signal. We called the Satellite company to come out and they said it was a problem with the TV. Any ideas what it could be?
  • 4,234 Answers
The other inputs bypass the tuner, so I'd be looking at tuner failure. RCA sets are known for having poor solder connections inside the tuners. I would start there. If you are not comfortable with working insode the set or can not solder, check with a local service shop to get an estimate for resoldering/replacing the tuner.
Dan
Posted on Feb 13, 2009
I cant get a singal for my antnna
Tv does work for HD but must have cable or satellite tv signal.Yes,this tv able to play HD signal,but it is a CRT-(tube tv) design was built before the DTV switch over and never added the DTV tuner in it board circuitries.Sorry antena free DTV this tv must have to added the converter box to get the DTV free air signal.
Feb 17, 2011 | RCA P61310 TV
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
Remote doesn't work rca model #F32648,i can't access the input function. The onscreen menu doesn't show it or I cannot find it. Problem is without it I can not use the DVD player.
This isn't a solution but I am unable to acccess the input either. My tv is hooked to a dvd,vcr and direct tv satellite with a dvr. I watched a movie on the dvd and the tv won;t allow me to switch the input back to satellite tv.
Apr 10, 2009 | RCA F32648 32" TV
Can't access video input channel
I believe you need the original remote to switch the input to video . I found the remote shown at PartStore.com with the original RCA part number 242524 at about $37.00 and also at MCMelectronics.com at around $31.00. There may be other sources also. Good luck.
Dec 30, 2008 | RCA F27628 27" TV
My new tv digital converter box weill not pass analog tv signals. The tv works fine if I take the box out of the circuit. I am in a motorhome using the normal tv antenna on the roof.
you need to split ant. signal then get a manual selector switch hook 1 wire to convertor input then the output& the other ant wire to the selector switch then from selector to tv
Dec 20, 2008 | RCA Televison & Video
RCA DSS Receiver remote codes
i need codes for pansat 2500a
Jun 16, 2008 | Televison & Video
No Sound
Maybe a vacant channel or input is tuned.
• If watching VCR (connected only through antenna input), make sure TV is tuned to channel 3 or 4 – same as CH3/4
switch on VCR. Also check to make sure the TV/VCR button on the VCR is in the correct “mode.”
• Simultaneously press the POWER and CHANNEL DOWN buttons on the front panel to reset the TV.
HOPE THIS WILL HELP YOU.. GOODLUCK
Jan 29, 2008 | RCA P61310 TV
Insufficient width
You can goto www.wa6ati.com and search for your model and it may tell you.
Dec 06, 2007 | RCA P61310 TV
Screen Broke
VanceBaldwin.com
Oct 04, 2007 | RCA P61310 TV
RCA P61310 TV Logo
94 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
