Question about Dryers
Dryer words (AF) what does this means?
I have a dryer that when I have it on, sometimes it shows the letter AF, can someone tell me what that means?
    President:
  • 1,902 Answers
Low air flow. Means that your vent is blocked or crushed and check your lint trap also
Posted on Feb 13, 2009
Kenmore Dryer 700S Check Vent is on and sometimes the letters AF appear in the iMessage remaining Box. The Vent has been checked and vacuumed, but light remains on
that code mean low air flow u clean vent hose did you check an make sure that there no lint build up the vent coming out of the back dryer were bent hose connect to back of dryer are if this a house are a apartment vent hose could be to long cause .
May 28, 2017 | Kenmore Dryers
What does it mean.when the AF button light on the dryer stays on
www.fixya.com/.../t26056154-mean_when_af_button_light_dryer_stays
20 mins ago - Low air flow. Means that your vent is blocked or crushed and check your lint trap also ... Hi Terry, AF flashes if a restricted airflow condition exists.
Jan 16, 2016 | Dryers
Estimated time remaining readout shows AF instead of the time left. It is a Kenmore 700 series dryer
AF stands for Algorithm Failure, which means that there is something preventing the dryer from calculating the remaining time. Try cleaning out the dryer drum and lint screen completely, then run the dryer with just a dry towel.
Feb 20, 2015 | Kenmore Dryers
When I turn the Dryer on there is the letters AF start flashing it is running and drys the close but it takes a lot longer than it did when I got it.
I've seen the AF code twice now on my Whirlpool Cabriolet Dryer (wed6400sw1). The first time, we thought it stood for "Auto Fluff", a cycle to keep the clothes wrinkle free...We soon realized the dryer was getting a lot hotter than it ever did before and until I checked the vent stack from the roof, I had no idea that the pipe was blocked with a build-up of lint. I cleaned the pipe from top to bottom by taking it apart wherever I could using a vacuum and every hose extension I could get my hands on. I duct taped these together so I didn't drop it somewhere that I couldn't reach!
The second time we saw the AF code was this weekend. First, I verified the vent pipe was not clogged again. (a good quick test for this is to disconnect it from the back of the dryer and run it unconnected to see if the AF code fires) After some online research, I started taking it apart the back to maybe replace the thermistor or the thermal fuse shown above.
I noticed an odd little piece of ceramic tubing had fallen down to the base of the dryer pan. So I decided to take the heater core apart to have a look. Sure enough, I found my problem. My dryer has two separate groups of springy looking heater wire. You can see that part here as well as the little tube I found. http://www.appliancepartspros.com/Appliance-Parts/whirlpool-element-item-number-ap3953732.aspx It turns out that ceramic tube is an insulator allowing for the two heating elements to exist without touching since they are both powered from the same starting wire point.
Well, my AF code (which is really just telling you the dryer is getting too hot) was being created due to a broken wire which caused the two units to fuse together. It must have been getting really hot. It also had welded itself to the metal backing structure.
I carefully removed the broken wires from the heater element and reassembled to test. Sure enough, it works good again and no AF code, but I bet it doesn't heat as much since I removed one half of the element. I'm going to pick up a replacement heater element tomorrow from the local parts store to restore it like new.
Hope this helps someone!
Mar 23, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool dryer Cabrio 6 months old. message on screen is "AF" what does that mean?
Code AF means the air flow is blocked.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 07, 2011 | Dryers
The letters AF come on. what does this mean? air filter problem? it is not drying.
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
Nov 25, 2010 | Dryers
The dryer display for the time is displaying "AF".
"AF" means there is an air flow problem within the venting system. There is either a restriction in the hose, outside vent cover, the front vent, or maybe the lower blower assist isn't rotating.
Nov 13, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
AF On Dryer
I went to Lowe's where I bought the washer and dryer and asked them about it. They told me what to do
May 11, 2009 | Maytag Bravos MTW6600T Top Load Washer
AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Mar 27, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
AF keeps showing up
AF is an AIR FLOW issue, youll need to check your venting for an obstruction.
Dec 07, 2008 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
148 people viewed this question
Top Dryers Experts
