Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Sound but no picture
I have a 53 inch rear projection tv the picture went out but sound still works i had the convergence board replaced about a year ago it worked fine then the picture went out when you turn it on the sound comes on the power light comes on and does not blink though and when you hit power it still makes that click noise like it usually does
  • mhwhite5 Feb 15, 2009
    I dunno last time when the convergence board went there was still some sort of picture now there is no picture when you look at it it looks like its not turned on, even if you hit the menu button still nothin shows up on the screen?
  • mhwhite5 Feb 16, 2009
    yea im pretty sure the board was replaced, yea the sound works you can still hear all that just the screen dosent turn on
    Brigadier General:
  • 8,619 Answers
Hi
From the information you have provided the problem is with the convergence. If you have gone into the menu after the TV has been on for an hour or more and tried adjusting the focus/conversion and the focus did not correct the problem the convergence ICs have failed and will need to be replaced along with a few defective resistors. If all the colors are incorrect a open fuse in the voltage supply to the amplifiers is possible.Convergence failure is a very common problem with this TV set. There could be other parts that are not within factory specs. The only way to be positive of the problem is to have the circuitry diagnosed by someone with the proper TV test equipment to determine what parts that are no longer within specs. A small TV repair shop will many times be less expensive than a large repair facility.
Please revert for further clarifications.
A Fixya Rating would be appreciated if you have found this information useful .
Thanks
Rylee
Posted on Feb 13, 2009
  • Rylee Smith
    Rylee Smith Feb 15, 2009
    Can you hear any sound from the tv? Have you replaced the convergence board or just replaced the convergence- stk ics?
Panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound
3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering.
Hope this will help.
Thanks.
Mar 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
51 Hitachi rear projection 6 years old, can't get it to focus, Has sound. Can only get the picture to come in abpout 80%. Around the perimeter, sports scores and subtitels are not readable. Used the fucus...
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Oct 13, 2010 | Hitachi 51F500 51" Rear Projection...
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Sony kp-53v90 no picture but has sound and display lettering
The tv have a problem known as a convergence problems,it dead.The tv convergence board require changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Sony KP-53V90 53" Rear Projection...
Lines around picture and words out of shape
It sounds convergence output chip failure problem.
Replace convergence output chips on D Board of tv to fix the picture issue. If you have no experience of working in tv circuit boards then ask local tech to help you out.
Thanks.
Jun 06, 2010 | Sony KP-51WS500 51" Rear Projection...
Pioneer 501-HD 53 Rear Projection TV- No Picture or Sound
your input board might be bad, does it work on any other inputs?
Oct 11, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Phillips 60 inch HD rear projection? Convergence!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 26, 2007 | Panasonic PT-53WX53 53" Rear Projection...
HITACHI 53UWX10BA
Hi there, Check IC601, C603 for leakage, I601 and vertical pulse detector QN05 for poor convergence check RK42 for open circuit. Best regards, Arpi
Jun 16, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
