Question about Toshiba 32A33 32" TV
A black box appears at the bottom of the screen
My husband was trying to program the TV using the universal remote. He did something that made a black box appear in the lower half of the screen. Now we can't get it to go away. Any ideas?
  • 4,234 Answers
It sounds like you have enabled Closed Captioning and the channel that you are watching does not have that info. There should be a way to turn it back off either directly with a button on the remote or throught the menus. Look for CC.
Dan
Posted on Feb 13, 2009
We have a naxa converter box with a GE universal remote searching for the code
About 17,100 results (0.72 seconds) Search Results
    GE Universal Remote Codes and Instructions ' direcTutor
    www.directutor.com/content/ge-universal-remote-instructions
    Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
    Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
    tv.manualsonline.com/support/...digital/tv-converter-box/code-1082992
    Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
    Trouble programming Universal Remote to a DTV Converter ...
    www.fixya.com/.../t2045188-trouble_programming_universal_remote_d...
    Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
    Control It All With Universal Remote Codes - Digital Landing '
Feb 08, 2016 | GE Televison & Video
On my TV certain shows (Craig Furgerson, Oprah, The View)on different networks,a black rectangle, about 1/3 of the picture, appears. I cannot remove it.
That box appears to be from the close caption feautre. If you have the original remote you can disable using the menu and go to audio functions and look for close caption to turn it OFF.
Do you have the user's guide for this TV?
If you do not, could you provide the model number of your TV?
Jul 24, 2008 | Sharp Televison & Video
I bought my husband a large or rather giant universal remote made by Gemini, however we cannot find a program code for his Accurian VCR/DVD player; my son was able to program his Vizio TV. Due to phys
hello.......Accurian vcr/dvd its a Radio shack product you can probably d/load manual..[2]gaint remote go to amazon its a Amer-Tac -zenith $12...i'm on amazon.... just hit Bose remote rc5...or....bookbundler@gmail.com
Feb 12, 2014 | Gemini 1 Device Universal Television...
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
TV screen has black square in middle- something w/the GE Universal remote programming... What?
Unhook everything and re hook it back up (or just unplug from the wall for 30 secs) and see if that helps, what kind of TV is it? Are you trying to set up a universal remote with it?
Apr 14, 2010 | Universal Remote Control GE174Universal...
Black box covers most of the tv screen.
Just use the remote to turn off the closed captioning,The button should be marked as CC or you can just go into the menu and turn it off.
Jun 02, 2009 | JVC Televison & Video
Black Rectangle Box appears shortly after turning on TV
That is the PIP (picture in picture) setting, on the TV's remote control. locate the button marked PIP and press the button, it should clear the little box.
Apr 04, 2017 | TruTech PVS31170S1W 17 in. LCD Television
Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Jun 04, 2008 | JVC AV-32260 32" TV
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Tv is locked
I had the exact problem...tried a number of things that did not work. My dog "ate" my original remote. After reading your solution I took the universal remote that was programmed to work with the tv and tried holding down each button for a few seconds hoping that one would work like the display button on the original remote. It worked. I have a GE universal remote and the menu/info button worked for me. Again, you need to hold it in for a couple of seconds. Thanks for the help and I hope my added solution helps other people. Claudia in Minnesota
Feb 15, 2007 | Haier HTF20R21 20" TV
Toshiba 32A33 32" TV Logo
105 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
